Dyno time for the TA again - estimates?
  • Thread starter Thread starter 89tang
  • Start date Start date Nov 16, 2006
  • 3
First Prev 3 of 3
89tang
2,508
Newark ohio
Nov 20, 2006
#41
  • Nov 20, 2006
  • #41
89white50 said:
Looks like i was DEAD on for BOTH the NA rwhp and nitrous pick-up can i have my medal now??
Yup just about right on it
_jb_
808
Michigan, Berrien County
Nov 21, 2006
#42
  • Nov 21, 2006
  • #42
Seems like if the car would not go rich, you would need a larger fuel pump and/or injectors. Have you changed them? Since yours is a 99, you have 26lbs injectors. I know my friend's injectors were maxing out (same injectors in 2000)
Glad to see you got more power. I had a 150 shot with just a lid and catback and made 390rwhp and 515rwtq on a Mustang dyno.
89tang
2,508
Newark ohio
Nov 21, 2006
#43
  • Nov 21, 2006
  • #43
It has 36lb injectors an a 255 pump, the fuel pressure is 60psi at idle so that's not the problem. The reason it won't go rich from how it was explained to me is because the nitrous was not hitting the MAF right. My tuner said there are 3 wires on the meter the two on the outside measure the air density the one in the middle measures ambient temp or something. Since i have only a single nozzle in the Lid it's going around the corner of the lid straight into the TB only hitting one one of the wires on the meter. I put a dual nozzle on it one on each side of the lid it will hit both wires on the meter. It doesn't fog up in the lid like you would think, its just a small stream that goes right around the corner of the lid straight for the TB. He said this had happened before on a single nozzle setup like mine. The other guy up a dual nozzle setup on it and it fixed the problem.
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Nov 21, 2006
#44
  • Nov 21, 2006
  • #44
Me sad after seeing that thing pull all the way to 7000rpm and actually make power that high up
Nice numbers
89tang
2,508
Newark ohio
Nov 21, 2006
#45
  • Nov 21, 2006
  • #45
Nice numbers
That's another thing with the A4 atleast on that dyno, it didn't go to 7k only went to 6400 that's where the rev limiter is. Redline is set at 7k though . The old cam i believe the rev limiter was set at 6100.
  • 3
First Prev 3 of 3
D
Engine Help! Having A Stroke Over My 331 Stroker...will Not Run Well
  • dalec91gt
  • Aug 6, 2012
Fox 5.0 Mustang Tech Aug 6, 2012
dalec91gt
D
Finally! A valid TFS-R and TFS Box R intake dyno comparison on a street stroker.
  • FastDriver
  • Oct 19, 2011
  • 2 3
39K
Fox 5.0 Mustang Tech Sep 6, 2025
FastDriver
331 dyno session
  • Markus
  • Sep 24, 2008
Fox 5.0 Mustang Tech Sep 24, 2008
Markus
New Track Times!!!!
  • go-stang5.0
  • Aug 12, 2004
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Aug 17, 2004
Stump1000
