)? Any other suggestions to put the peak on my power curve?GRGT1994 said:It feels great, SOTP improvement is noticable. We didn't capture a baseline before the PMS, so no measured comparison. But looking at what I pulled on a few runs with my Gtech, I went from a best 0 to 60 before of about 5.1 seconds down to 4.8. And the 5.1 before was kindof a freek run (maybe I caught the wind or was on a downhill?). My typical strong run to 60 before was about 5.5.
I didn't think high flow cats would make much difference. But the curve does look pretty flat at the top. That might be desirable in a street car, but it also might confirm what you guys suggested above (delete the cats and switch to a track heat upper).
I don't really want the volume of a cat-less mid pipe. Any way to lose the cats but quiet it down (other than turbos)? Any other suggestions to put the peak on my power curve?
Thx for the clarification. That is all way over my head. Part of the reason I went to AFM to have someone else tune. Looks like I need to start doing some read'n and learn'n on all this stuff.Grn92LX said:Grady, if you look at the graph you'll see it says "+10 +10 +8 +8". Thats the timing curve added in to the PMS. Assumming he has stand alone ON (it only comes on at 4000 rpm in pre 04 PMS's) that means his WOT timing is 35* total from 4000 and up until it hits 6000, its 33* total. In standalone the PMS sets the total timing to 25* + what you add in.
His curve in the PMS would be 2200 +10, 4000 +10, 6000 +8, 7800 +8
yesbimmertech said:just curious if the a/f was read by a wideband?
GRGT1994 said:yes
Question: What might the trade off be (if any) by changing to a Track Heat upper?
Black95GTS said:Your power band will shift up. The car will want to rev a little higher, but with a 4.10 screw that won't be an issue.
Adam
Grn92LX said:Since you have 4.10 gears, swapping to a track heat manifold would help up top.
