  • SN95 4.6L Mustang Tech
e brake light problems
  • Thread starter Thread starter brent_cosenza
  • Start date Start date Oct 17, 2006
brent_cosenza
70
Georgia
Oct 17, 2006
  • Oct 17, 2006
when i give my car full throttle then let off the brake light comes on and i give it gas again then it goes off the light also comes on when i push the brake i have checked the brake fluid and its fine any help would be greatly appreciated cuz man its annoying...
Mustang5L5
Mod Dude
Feb 18, 2001
43,348
18,083
224
Massachusetts
Oct 17, 2006
  • Oct 17, 2006
Most likely it's the fluid sensor in the reseviour. Mine does this as well during HARD braking. The fluid sloshing around can cause it to rise and dip setting off the light.
Mustang5L5
Mod Dude
Feb 18, 2001
43,348
18,083
224
Massachusetts
Oct 17, 2006
  • Oct 17, 2006
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Oct 17, 2006
  • Oct 17, 2006
brent_cosenza said:
I have checked the brake fluid and its fine
So the fluid level has been visually inspected and it is ok? Its low or, like Mike said, its sloshing around... Check the low fluid sensor plug connecter and the low fluid sensor wiring also, just in case.
DTMach1
240
Virginia Beach, VA
Oct 18, 2006
  • Oct 18, 2006
When the res. is all the way full there should not be enough "sloshing" as described to trip the sensor.
More than likely you're getting the light because your pads are getting worn which means your pistons have extended causing your fluid level to drop. You can either add more fluid and the light will go away, or you can change your pads and add fluid afterwards.
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
R
Electrical 1987 Map Light
  • Riley Barth
  • May 30, 2026
Fox 5.0 Mustang Tech Jul 6, 2026
Riley Barth
R
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
