  • SN95 4.6L Mustang Tech
E-brake light when braking
  • Thread starter Thread starter merc123
  • Start date Start date Sep 26, 2006
merc123
420
North GA
Sep 26, 2006
  • Sep 26, 2006
I was messing around with hard braking tonight and if I got up to about 70 and hit the brakes hard (not slammed, just hard) the e-brake light would come on until about 20-30 MPH and then go off. I checked the e-brake but there isn't anything under it to pull it up or anything. No ABS lights or anything else came on. Any ideas?
jivepepper
776
Under a Sombrero. in WV.
Sep 27, 2006
  • Sep 27, 2006
Isn't the light also for other braking problems like low fluid level?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Sep 27, 2006
  • Sep 27, 2006
that light is also used to tell you about other problems in the brake system.
check your fluid level in your master cyl. as the pads wear out the fluid level drops, so you may just need brakes.
Dope 97GT
439
Rochester, NY (SUNY Brockport)
Sep 27, 2006
  • Sep 27, 2006
+1 that exact same thing happened to me the pads were worn and the light would come on under a little more heavy braking. I changed the pads and the light went out.
merc123
420
North GA
Sep 27, 2006
  • Sep 27, 2006
Works for me. That sucks because these pads are brand new. I had them put on back in May...
Mike97gt
it doe snot
10,633
Sep 27, 2006
  • Sep 27, 2006
Did you replace front and rear pads? If so you might have other brake issues like a fluid leak
merc123
420
North GA
Sep 27, 2006
  • Sep 27, 2006
Yeah. Front and rears. I noticed the fluid level is low though. I'll add some and see what happens in the next week or so. I'll also check the pads. They're hawk pads and some say they don't last long.
Dope 97GT
439
Sep 27, 2006
  • Sep 27, 2006
Fluid being low will do it as well because thats basically how it tells if your pads are worn if the fluid drops so fill it up and you should be good to go.
saleen137
199
Bellflower
Sep 27, 2006
  • Sep 27, 2006
+2 but the difference with me was that the brake fluid was low. So I added some and problem solved
merc123
420
North GA
Sep 27, 2006
#10
  • Sep 27, 2006
  • #10
Added fluid today. My current fluid looks pretty dirty so I may get it flushed or do it myself. Plus S/S brake lines are cheap around here so I think I'm going to add them too.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
1970 brake issue. Bad booster or?
  • All Stock93
  • May 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Sep 13, 2025
All Stock93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
