E7 woes
  • Thread starter Thread starter mustangmods
  • Start date Start date Dec 9, 2005
M
mustangmods
49
  • Dec 9, 2005
I'm trying to make a 5.0 HO out of a 1987 5.0 that has the "high swirl" heads, which suc. So my question is: Are they any other heads out there,besides aftermarket, that will compete with the E7? I have a pair of E5CA's and what I believe are E8 truck heads, Will any of these work well a stock HO cam? And one more thing.. What possible harm would be done by using A maf conversion kit with stock heads, stock pistons,HO cam, 70mm TB and egr spacer with matching typhoon intake? would updating to better heads round out the engine more. Kinda got stuck with the 70mm Thottle body.
TomCat
412
Utah
Dec 10, 2005
  • Dec 10, 2005
Can't you just get ahold of some E7s? They seem to be really cheap.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Dec 10, 2005
  • Dec 10, 2005
i think guys on budgets get gt-40 explorer heads.
Euphoric306
905
  • Dec 10, 2005
+1 for the explorer heads, ported they can compete fairly well with some of the aftermarkets, at a much lower cost
V
v8only
2,378
22
49
Dec 10, 2005
  • Dec 10, 2005
70 is way too big. stick with the stock 60 for a stock motor.
the e5 heads are nearly identical to e7 heads.
M
mustangmods
49
  • Dec 10, 2005
The stock 5.0 motor in 1987 came with a 50mm throttle body with an engine compression of 8:5:1. I've been told the difference is in the heads and the cam and of course the larger TB. So the E5CE should work well. Will it raise the compression?
V
v8only
2,378
22
49
Dec 12, 2005
  • Dec 12, 2005
smaller non ho throttle bodies were 58 mm, same as the 86gt engine with the e6 heads. All other 5.0 ho's 87+ got 60mm from the factory. NON 5.0 ho engines likely got the 60, but at a minimum recieved the 58. there was no 50 mm throttle body for the 5.0 engine. the e5 head simply designates the 85 year. the 85 year HO mustang head (possibly the cfi head too? not sure on that) is near identical to the 87 head. it'll have virtually no hp differences.
M
mustangmods
49
  • Dec 12, 2005
You guys are thinking mustang.. this is 5.0 tech remember. The engine is out of a lincoln, so its pretty much a couger engine. It has a small TB with 14lb/hr injectors. Ford books list it as having a 50mm tb. Not that it matters cause now I have a 65mm. The heads look nothing alike. Set a e5 next to a e7 and look at the chamber style and volume. The e7 has 64cc the e5 looks to have much more volume hence lower comppression.
V
v8only
2,378
22
49
Dec 12, 2005
  • Dec 12, 2005
very interesting, i was under the impression otherwise. Good info to have.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Dec 12, 2005
#10
  • Dec 12, 2005
  • #10
E5s have 69cc chambers E7TEs are 62.1cc E7AE are 64.4cc
M
mustangmods
49
#11
  • Dec 12, 2005
  • #11
the exact number on my heads are e7te-pa. I measured the chamber volume using a hypodermic needle once the heads was on a level surface. So at best it was a ball park figure at 64 cc but thanks for the info.
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Dec 12, 2005
#12
  • Dec 12, 2005
  • #12
i have a set of fully build E7's.. 1.84 valves and hugely ported to no end.. they compete.. compete really well with a high compression motor lol
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
Engine HCI Upgrade
  • foxbodyclark
  • Jan 21, 2025
Fox 5.0 Mustang Tech Jan 26, 2025
Mustang5L5
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
