e7heads FIT ON AN E6 BLOCK WITH FLAT TOPS?
2.3lover
21
will i have to flycut the stock 1986 flat top pistons since they have no reliefs in them,,i want to put some e7 heads,,,will the compression be too high?? the block is roller cammed,,,thanks
It's really not a good idea to assume anything, you really should check the clearance.
That said, I didn't check the clearance and I've had no issues, compression doesn't move up all that much.
Seriously though, it worked for me and I was lucky, not wise.
Be smarter and check your clearance.
