early 4.6l B-series head question???
putnam88
102
31
tavares
I have a 93' Lincoln mark VIII 4.6L with the B-series heads. My question is this, do you need to run the intake manifold runner control, used to separate the primary and secondary runners. can you eliminate it or will it affect performance in any way. reason being intakes for this motor i have found to insanely priced. and am going to give making my own a shot. and for calculation reasons need to know if i need the imrc plates.
any info would be greatly appreciated
-steven-
  • Sponsors(?)
putnam88
102
31
tavares
i have also made stainless steel plates for the valve covers to convert it to coil on plug and ideas on what would be the best coil to run
bhuff30
6,035
35
129
Olathe KS
I would say yes, you need to keep the plate. The idea of the different runners is to better tune the intake for a wider operating range. This allows the engine to operate on one runner during low speed operation for better low rpm torque and around town manners, and still allows another runner to open up and feed the engine more air the upper rpm range. Often, the runners are a different diameter or length to tune for a certain operating band. Shorter and fatter primaries favor the high revs, while skinnier and longer primaries favor the lower rpm range.
Looks like the B heads have two intake ports for each cylinder cast into the head itself. Sure, you could build a manifold to eliminate the plates and dual runners, but this would likely hurt the low and mid range torque quite a bit.
putnam88
102
31
tavares
yeah that's what i was wondering. to give an idea the car is going to be turbo-ed. know i don't how much that changes the factor due to the turbo forcing the air and the engine not being n/a. i had also in my searches found that ford racing makes a delete plate. it is the same width so on and so forth just says removes the shaft and blades. cause i am trying to gain all the info to compile into one basic design for the intake.
thanks for all the help
-steven
Thread starter Similar threads Forum Replies Date
V Early fox body dual exhaust conversion questions Fox 5.0 Mustang Tech 4
S 4.2 crank/rods/pistons in a early non roller cam 3.8 v6 block ? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
DarkFox I'm a new stangnet member and I am removing the :poo:ty early 90's alarm system in my car. Northeast Ohio failure here. The Welcome Wagon 21
M TR3650 dragging noise early in gears low rpms 1996 - 2004 SN95 Mustang -General/Talk- 1
S Engine Can I switch to an early model steel geared, non-retard cam drive on my carburated 1986 ,5.0 HO engine? Fox 5.0 Mustang Tech 1
DAJ352 Old School 5.0 Very cool stuff from the early days of the movement 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 26
B early bronco megasquirt pnp2 amortization thread Digital Self-tuning Forum 20
8 Progress Thread Early 83 GT 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
T Looking for Car and Driver Story - early 80's? 1965 - 1973 Classic Mustangs -General/Talk- 3
R Early Frame rails The Welcome Wagon 4
geoklass RCI Headers for early Mustangs... 1965 - 1973 Classic Mustangs -General/Talk- 1
F Billet T-Top Handles Late 80's - Early 88 T-Top Mustangs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
M speedway early mustang cross member with 351W 1965 - 1973 Classic Mustangs -General/Talk- 3
B 5.0 engine swap into early Bronco The Welcome Wagon 3
MoDriver SOLD Dr. Gas Exhaust X-pipe 3" X 3" Kit With Summit Header Collector Exhaust 0
Chythar Interior and Upholstery Got Myself An Early Xmas Gift 1994 - 1995 Specific Tech 7
cleanLX Favorite Car Of Your Teens/early Years... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 55
MoDriver SOLD Early Model Exhaust With Dr. Gas X-pipe Exhaust 0
wgreenlee4 Help! 1992 Early Vs Late K-member: Which Motor Mounts??? Fox 5.0 Mustang Tech 5
RacerJames What's The Difference Between My Early 351 W Heads? 1965 - 1973 Classic Mustangs -General/Talk- 1
C Ready To Swap 5.0 Into Early Mustang-computer Question Fox 5.0 Mustang Tech 0
onetricpony Early C4 Linkage Adjustment? 1965 - 1973 Classic Mustangs -General/Talk- 8
enyawix Did The 5.0 Explorer And Early 4.6 Use The Same Engine Management System? SN95 4.6L Mustang Tech 2
bdepedro Early Interior Door Handles On 69/70 1965 - 1973 Classic Mustangs -General/Talk- 1
motherhd Early 302 Block Questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
68dustin New Mustang Leaked Early? 2015+ (S550) Mustang -General/Talk 22
M Expired 1976-1978 Lincoln Versailes Disc Brake Rearend For Early Mustang Swap Drivetrain Parts 1
M66 Expired B&m Torque Converter For Early C4 Drivetrain Parts 0
J Transmission shifts early during WOT Fox 5.0 Mustang Tech 15
Mr_Q Drivetrain Hurst/b&m/ford Racing Shifter For Early V6s! 2005 - 2014 Specific V6 Tech 0
oz What Is Needed To Swap Early 302 To Fox 5.0??? Classic Mustang Specific Tech 13
CarMichael Angelo Is it too early to talk about Mustang week? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 25
SteedaGT9150 Christmas Came Early 1996 - 2004 SN95 Mustang -General/Talk- 2
Fullmetalocm Rear tires worn out too early on 2011 GT 2005 - 2014 S-197 Mustang -General/Talk- 19
R early 60s ford 9 inch question Classic Mustang Specific Tech 6
S Which Fox body drivetrain fits our early cars? Classic Mustang Specific Tech 7
O Very Early toploader Drivetrain Parts 0
FatBoss Any interest in really early hipo 289 block? Drivetrain Parts 1
O WHY?? not many early 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
R Early production 302s 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
6 bleeding early 302 cooling system Classic Mustang Specific Tech 6
S Has anyone had their early block machined to take a one piece seal? Classic Mustang Specific Tech 8
C EFI upgrade on early 289 advice.... Classic Mustang Specific Tech 2
ufnavy06 Was told the first Bosses will show up early March 2005 - 2014 S-197 Mustang -General/Talk- 3
0 Trans Swap - Early 2001 or later? Different clutch, flywheel? SN95 4.6L Mustang Tech 3
duo_z Early Style 289 Timing Cover Classic Mustang Specific Tech 26
A JLT Performance's Early 3.7L V6 CAI Testing 2010 - 2014 Specific Tech 1
Edster Early C-4 problem. Classic Mustang Specific Tech 4
F Clevite Pistons .030 for early fox Engine and Power Adder 0
T Late fox dash in a early fox swap. Who's done it? I need help. Fox 5.0 Mustang Tech 4
