early models 320 heads on 5.0
Tn-mustang
22
Will a set of early model 1970 302DOOE work with a late model 1990 5.0? I have aset of these heads that have been ported and have the larger 1.94/1.6 valves with 58 cc chambers that I am thinking about putting on a 5.0. The engine will be carbureted and have a hydarulic roller cam such as the b cam with roller lifters. Thanks. The reason that I ask is that I am fairly familair with the early model stuff and found a good deal on a 5.0 to put in my 66 mustang. I still want to run on pump gas.
  • Sponsors(?)
85_SS_302_Coupe
6,933
1,585
223
40
Northern KY
If my '69 C9 351W heads will bolt to an '85 block (with the right studs of course) then i would think you'll be fine.
5.0fox
410
32
buckley/enumclaw wa
i run do0e heads on my 87. the only thing you need are head bolt guides or hardened washers for the headbolts because the 351 has bigger bolts then the 302.
thumper460
3,022
Orange Park , Fl
Thumperoforangepark.com
Yes.. if the heads are ported then the older style heads will be fine!! The exhaust is really tight do to the EGR/Air Bump.. but if that has been removed and the larger valves... you should notice a good gain in power!!
Note here.. the 1.94 valve size is "Out of the pocket" on the stock piston!! Lay the head on the block ( well ok Bolt it on with out the head gasket and you dont need to torque it..) stick on the rocker and pushrod.. turn the engine over by hand.. check just to the outside if the valve notch in the piston.. there might be a small ding from the larger valve!! If there is just lay back the notch and your good to go.. cool?? Have fun!!
Just me..........................
Thumper
Tn-mustang
22
what did you do for pushrod length
did you have to custom order? I would assume that the geometry of the heads and the lnght would still be the same so that I could just use standard length 5.0 pushrods. Anyone have any experience with this? Thansk for the help.
tb9050lx
155
ct
standard lenght 5.0 rods would be to short due to the roller cam and the heads not having the pedalestal mounts. best bet is to get an adustable pushrod from summit and ck the correct length.
Thread starter Similar threads Forum Replies Date
S Engine Can I switch to an early model steel geared, non-retard cam drive on my carburated 1986 ,5.0 HO engine? Fox 5.0 Mustang Tech 1
MoDriver SOLD Dr. Gas Exhaust X-pipe 3" X 3" Kit With Summit Header Collector Exhaust 0
MoDriver SOLD Early Model Exhaust With Dr. Gas X-pipe Exhaust 0
tommytorino 5.0 into early model look in here! Classic Mustang Specific Tech 24
R Fuel Injection on Early Model Mustangs Classic Mustang Specific Tech 18
thehueypilot Bolt circle size difference between early and late models? Classic Mustang Specific Tech 5
bullitt77 Any big Mustang registries for early models? (1969) 1965 - 1973 Classic Mustangs -General/Talk- 6
HistoricMustang Pretty cool road race early model! Classic Mustang Specific Tech 5
fox-gt Dallas Mustang has Early Model Diagrams online. 1965 - 1973 Classic Mustangs -General/Talk- 0
D Late model rims on an early model mustang Classic Mustang Specific Tech 1
HistoricMustang Get out and enjoy those early models! Classic Mustang Specific Tech 3
HistoricMustang No it is not an early model, but yes I race with this guy.......... Classic Mustang Specific Tech 9
IN2DEEP Early model T5 bellhousing needed?? 2.3L (N/A & Turbo) Tech 0
V Early fox body dual exhaust conversion questions Fox 5.0 Mustang Tech 4
S 4.2 crank/rods/pistons in a early non roller cam 3.8 v6 block ? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
DarkFox I'm a new stangnet member and I am removing the :poo:ty early 90's alarm system in my car. Northeast Ohio failure here. The Welcome Wagon 21
M TR3650 dragging noise early in gears low rpms 1996 - 2004 SN95 Mustang -General/Talk- 1
DAJ352 Old School 5.0 Very cool stuff from the early days of the movement 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 26
B early bronco megasquirt pnp2 amortization thread Digital Self-tuning Forum 20
8 Progress Thread Early 83 GT 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
T Looking for Car and Driver Story - early 80's? 1965 - 1973 Classic Mustangs -General/Talk- 3
R Early Frame rails The Welcome Wagon 4
geoklass RCI Headers for early Mustangs... 1965 - 1973 Classic Mustangs -General/Talk- 1
F Billet T-Top Handles Late 80's - Early 88 T-Top Mustangs 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
M speedway early mustang cross member with 351W 1965 - 1973 Classic Mustangs -General/Talk- 3
B 5.0 engine swap into early Bronco The Welcome Wagon 3
Chythar Interior and Upholstery Got Myself An Early Xmas Gift 1994 - 1995 Specific Tech 7
cleanLX Favorite Car Of Your Teens/early Years... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 55
wgreenlee4 Help! 1992 Early Vs Late K-member: Which Motor Mounts??? Fox 5.0 Mustang Tech 5
RacerJames What's The Difference Between My Early 351 W Heads? 1965 - 1973 Classic Mustangs -General/Talk- 1
C Ready To Swap 5.0 Into Early Mustang-computer Question Fox 5.0 Mustang Tech 0
onetricpony Early C4 Linkage Adjustment? 1965 - 1973 Classic Mustangs -General/Talk- 8
enyawix Did The 5.0 Explorer And Early 4.6 Use The Same Engine Management System? SN95 4.6L Mustang Tech 2
bdepedro Early Interior Door Handles On 69/70 1965 - 1973 Classic Mustangs -General/Talk- 1
motherhd Early 302 Block Questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
68dustin New Mustang Leaked Early? 2015+ (S550) Mustang -General/Talk 22
M Expired 1976-1978 Lincoln Versailes Disc Brake Rearend For Early Mustang Swap Drivetrain Parts 1
M66 Expired B&m Torque Converter For Early C4 Drivetrain Parts 0
J Transmission shifts early during WOT Fox 5.0 Mustang Tech 15
putnam88 early 4.6l B-series head question??? SN95 4.6L Mustang Tech 3
Mr_Q Drivetrain Hurst/b&m/ford Racing Shifter For Early V6s! 2005 - 2014 Specific V6 Tech 0
oz What Is Needed To Swap Early 302 To Fox 5.0??? Classic Mustang Specific Tech 13
CarMichael Angelo Is it too early to talk about Mustang week? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 25
SteedaGT9150 Christmas Came Early 1996 - 2004 SN95 Mustang -General/Talk- 2
Fullmetalocm Rear tires worn out too early on 2011 GT 2005 - 2014 S-197 Mustang -General/Talk- 19
R early 60s ford 9 inch question Classic Mustang Specific Tech 6
S Which Fox body drivetrain fits our early cars? Classic Mustang Specific Tech 7
O Very Early toploader Drivetrain Parts 0
FatBoss Any interest in really early hipo 289 block? Drivetrain Parts 1
O WHY?? not many early 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
