Look at the power curve and determine for that....about 6000-6200 for an auto with stock heads and cams and 5600-5800 with a 5 speed.......is where you will do the best at the track during shifting.......you need to stay where the power is not the RPM's.....about 6200 peak with stock cams at WOT.......with a good set of cams and springs....then you can rev much higher.....
"ED"
