  • SN95 V6 Mustang Tech
ebrakes not holding
  • Thread starter Thread starter gary247
  • Start date Start date Jul 6, 2011
G
gary247
  • Jul 6, 2011
I had the rear passenger side brake caliper changed due to a damaged seal. I changed the pads and rotors at the same time as the right caliper. Now my ebrake does not hold the car on an incline. I took it to another shop and they told me that the replaced caliper was not working correctly so I had them change it. No improvement. Other than the pads being glazed over (NAPA's best pads) I do not know what to correct. The brake lever seems to be pulling the cable tight. If I raise both rear tires off the ground the left wheel holds fine but the right does not which tells me the cables might not be even but I do not see any adjustment on the equilizer. Any one run into this problem?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jul 7, 2011
  • Jul 7, 2011
Check BOTH sides for slid pin galling to the bracket. Common Mustang problem. The slid pins MUST be able to move freely for the brakes to adjust and hold correctly.
G
gary247
  • Jul 7, 2011
slide pins
Seems like two of the mechanics who have taken the caliper off and replaced them would have noticed if the slide pins were bad before putting the unit back on the car. The side that did not get changed works as it should.
MustangLX-5.0
856
Lehigh Acres Fla.
Jul 8, 2011
  • Jul 8, 2011
If one caliper is replaced, the other on the rear should be replaced as well. These things should be replaced in pairs. The shop should have told you that in advance. Your problem is one of 2 things. 1 - as I stated, they should be replaced in pairs, and the problem could be that the drivers side calipers piston is so worn that it moves too easily allowing the drivers side to move before the passenger side. or 2. the slide pin on the passenger side is sticking due to corrosion and/or lack of caliper grease. Clean corrosion off pin and apply grease to pin then reassemble.
One other thing I forgot to mention. There could be air in the brake line on the passenger side, not allowing it to function properly. It's possible the lines weren't bled properly.
The drivers side caliper could be sticking IN a little but not retracting all the way. Thats a slight possibility.
G
gary247
  • Oct 6, 2011
EBRAKES
After being told and paying to have the replaced caliper replaced itself I asked the mechanic to take the tension off the cable and redo it at the brake lever. It as just a simple matter that the tension had not been released on the brake lever the first go around as was described one should do in the tech manual. A fifteen minute fix and no cost, this I found out after spending 350 dollars.
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
Brake issue after changing pads and rotors
  • squirrel0420
  • Jul 14, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jul 18, 2025
nickyb
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
L
05GT brakes on a 98GT?
  • lparsons42
  • Sep 6, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2025
lparsons42
L
