Hey Guys,
I've got the dreaded ecm 41 and 91 codes on my 92 Fox with KOER and i've thrown the book at it.
Fuel pressure is 39/40 with the vacuum disconnected from the regulator.
--Changed the regulator and fuel pump anyway
-- New Ignition/complete tuneup, plugs, wires, cap, rotor, coil etc.
-- New PCV valve
-- base timing set at 14 deg
-- New 02 sensors on both sides (good power and ground all the way to the sensors)
-- Egr Delete with the resistor triangle installed
-- smog pump delete (Thermactor tube just bent over? done by prev owner)
-- Long tube headers
-- cat delete with H-pipe installed
-- All vacuum lines capped off except for brake booster and fuel pressure regulator
The only thing I can think is that I'm sucking air through the thermactor tube thats bent in half on the passenger side, I've got the plugs to go into the heads but it's going to be a PITA getting them in back there.
Anyone have any other ideas, tips or advice?
-- New PCV valve
