  • 2.3L (N/A & Turbo) Tech
ECT ?
  • Thread starter Thread starter manny
  • Start date Start date Aug 13, 2007
M
manny
590
TAMPA FL
Aug 13, 2007
  • Aug 13, 2007
Does any one know on the ECT sensor which wire to splice and install an adjustable trim pot in order to change what the ECU is getting. what about the value for the trim pot? what i am trying to achieve is a richer mixture of fuel and air . thank you
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Aug 14, 2007
  • Aug 14, 2007
The stock sensor does not react in a linear fashion. Messing with the signal will have mixed results depending on actual coolant temp.
You would be better off raising the fuel pressure or using a lower temp thermostat.
M
manny
590
TAMPA FL
Aug 15, 2007
  • Aug 15, 2007
what i am trying to do is to change the duty cycle of the injectors, that way they stay open just a little bit lomger to get more fuel in the cylinders. right now i'm running 50 PSI of fuel pressure and she runs lean on the higher rpm range, just trying to get more fuel into the motor.
65ShelbyClone
4,675
38
119
Aug 15, 2007
  • Aug 15, 2007
Jeez, is this a turbo engine or something?
It's likely that your injectors are already maxed out.
bhuff30
6,037
35
129
Olathe KS
Aug 16, 2007
  • Aug 16, 2007
Try 52 psi Are you sure fuel pressure holds steady at higher rpms and doesn't drop off?
I can't remember what year your car is, does the car have speed density or the MAF?
Here is all the info you could need on the ford ECT sensor: http://www.fordfuelinjection.com/index.php?p=28
As 65clone said, you probably just don't have enough injector. Additionaly, high impedance injectors (as you have) have a limited duty cycle. You can try to trick the computer into giving it a higher duty cycle, but that style injector can't physically stay open more than about 90%.
On my 2.3T, I've run as much as 60psi base fuel pressure. Then, adding 20psi of boost, the pressure could hit 80. Yeah, excessive, but it did the job.
M
manny
590
TAMPA FL
Aug 18, 2007
  • Aug 18, 2007
thank you very very very much. lots of info there
  • dan50
  • Jul 18, 2026
dan50
R
93 LX 2.3 Trouble codes 53, 85, 21 help
  • Rickshaw302
  • Apr 15, 2025
2.3L (N/A & Turbo) Tech Apr 18, 2025
AeroCoupe
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
