ECU and igintion components for 1992 Mustang
johnthomas104
I did an 4cyl to V8 conversion. I have since realized that all ford components are not the same. I have 1992 Mustang body and have a 1990 engine. The car is running a T5 speed. I have a C3W computer which is wrong(it is for an automatic car). I recently discovered that there is a difference in the distributor control module. The control module is for an automatic car as well. I have an A9L computer that I tried to hook up and the car would run, but it would not pull. My questions are listed below. The car runs strong & fast. Hard starting, excess fuel consumption. I am trying to get it to be dependible
Do I have to run a Manual computer in my car? (I know these affects ignition timing)
Do I need to change the ingnition control module for a manual?
Are the pin locations all the same on on A9L computers. I read a post that ford changed the wiring one year.(I.E. fuel pump) Mine is a E9.
What engineering code A9L will work with the 1992 car?
Any advice would be nice thanks.
You will need to run a computer for a 5- speed and get a control module for a 5speed.And i think you are burning a lot of fuel because you need a bigger pump.If you did not change the pump then you will need a bigger pump you will need one for 5.0 motor. The 4 cyl pump will work but i will not supply the fuel needed for a V8 motor that's way it's burning so much fuel.Keep me posted good luck.
