Ecu Upgrade Options
jcorkin
I am running a twin 67mm turbo setup on a 306 with scat crank, rods, and pistons at 10:1 compression and 15psi. Also have other supporting mods but the stock 91 ecu with a program flash needs to go and wondering what is recommended. Right now im looking at a MegaSquirtPNP Model #EEC4A8. Anybody have any experience with running the Megasquirt? Or is there something better at nearly the same price?
http://www.stangnet.com/mustang-forums/threads/steves-megasquirt-tunerstudio-help-thread.888730/
Hello my name is Steve I run the Mega Squirt help thread here. The big thing is that all your tuning software has a learning curve, I would suggest setting the waste gates wide open (to limit boost) until you get comfortable with the program. We have a wealth of information here and I can supply you with a solid base tune to get you rolling.
Other options this unit is a Stinger Pimp but uses MS3 tech and software so I can still help and is relevant in the help thread.
@Stinger
Reactions: 90sickfox
