Ed Curtis used cam and lifters
HotFox
1,069
701
164
SE Michigan
This is an Ed Curtis (Flow Tech Induction) used hydraulic roller cam .5745/.5700 lift 248/250 duration. Also includes lifters with guides/tray, pushrods, rockers 7/16 screw in studs, guide plates. Used on AFR heads see cam sheet power curve.
One pushrod is bent, along with broken guide plate, two rockers may have to be replaced due to bad needles in the tips. The engine got over revved at the track and lifters pumped up causing bent pushrod and broke guide plate from banging around and managed to break boss off head hurting two rockers.
I have attached picture of dyno sheet of a 327cid with AFR 185 cylinders heads, 10.5:1 comp, 750cfm carb, and long tube headers made with this cam.
I can assure you this cam is in great shape and with the replacement of the broken parts will work well. Broken parts are included in deal.
Went to a solid roller cam and no longer need parts
All lifters seem to be in great shape.
$150.00 OBO shipping included
Email: [email protected]
Thanks for looking
Scott
