Edel. Performer RPM heads on '66 289 ci
  • Thread starter Thread starter pazcarguy
  • Start date Start date Sep 11, 2008
P
pazcarguy
65
Pittsburgh, PA
Sep 11, 2008
  • Sep 11, 2008
I just had my short block redone to install the Edelbrock top end kit on my 1966 289. I am getting misleading info from Edelbrock thru their e-mail tech and also while waiting on the phone and actually speaking to someone in person from Edelbrock. My question is ,who has put these on a 289 and what is involved with the head bolts? I am purchasing kit #2091 from Summit that states it will fit on either a 289 or 302. I understand that the head bolts are different for the two different engines, is this correct? If so, Edelbrock e-mail tech line tells me I have to buy their head bushing kit and new head bolts for an additional $110.00., their phone people tell me just the bushings need bought. It doesn't make sense as the thread size,pitch and head bolthole ID are the factors involved Will the original bolts (included in kit #2091 work) or do I just have to buy bushings or do I have to buy both? It is misleading that both Edelbrock and Summit sell these for both engines but then tell you later that the bolts included in the kit won't work. just trying to sort thru the BS before commiting as it appears that Edelbrocks left and right hands aren't talking to one another. Thanks, Brian
H
hsr
138
Riverview, MI USA
Sep 11, 2008
  • Sep 11, 2008
I have Edelbrock Performer heads. They were on my 289 and now on my 5.0/302. I used the same ARP studs on both the 289 and 302. The thread pitch is the same and both take 7/16" diameter. Can't see any reason you need new bolts, UNLESS the mounting bosses are thicker on the Edelbrocks than your stock irons (meaning LONGER bolts), as I went to studs and never comparred them to the length of the stock bolts.
The heads have clearance holes for 1/2" head bolts/studs so they will fit on 351W as well. Yes, you will need the bushings to reduce the holes for your 7/16" bolts/studs. That kit EDL-9680 is $49.95 from Summit.
65fastbackresto
1,229
AR
Sep 11, 2008
  • Sep 11, 2008
Dont forget the steam holes.....
I have Performer RPM`s on an older 302 as well, and my builder did not drill the steam holes in the block as instructed with the heads. I have a motor that will not stay cool at idle no matter what I do (electric fan is next on the list).
Trust me on this, this single issue has caused me more aggravasion then any other thing on the car, I`ll never be able to ride in a parade, stop and go traffic is a no no, and this is after me spending $700 on a griffin radiator, and another $200 on a ho flow water pump.
I hope you went the 1.90 valves right? The 2.02 are overkill.
mrmustangman357
763
Sep 11, 2008
  • Sep 11, 2008
2.02 are not overkill. you need to buy just the bushings for those heads. there is no difference in head bolts between a 289 and a 302
coolblue65
1,224
Algonquin, IL
Sep 11, 2008
  • Sep 11, 2008
Couple things.
Just so you know the bushings are esentially a fancy washer, that fills the space for the smaller 289/302 block's head bolts. And yes as already said you do need them.
As far as the valve sizes are concerned, if you are using flat top pistons the 2.02" valves probably wont fit unless the pistons are notched for them.
P
pazcarguy
65
Pittsburgh, PA
Sep 12, 2008
  • Sep 12, 2008
Additional Edelbrock info
I received an e-mail from their tech support (late last night) who now tell me that both the corect head bolts and bushings are included in the kit. My "new" concern is that I had a response on the forum that steam holes needed drilled in the block (someones experience). excuse my ignorance, but what the hell are these for and why are they needed? I already have my short block done and don't want to tear apart for additional machine work. This was never discussed with my conversations with Edelbrock before, they just stated you need 9.5~10~1CR to make their stated power claims using flattop pistons with valve reliefs. Any ideas? Brian
G
GNGREN
144
Carroll Valley, PA
Sep 12, 2008
  • Sep 12, 2008
You didn't mention the part# for the heads you have.
Follow this link and look at #1 under Installation. If you have a 289 block I would say it needs drilled.
Edelbrock install instructions for steam holes
H
hsr
138
Riverview, MI USA
Sep 12, 2008
  • Sep 12, 2008
http://www.edelbrock.com/automotive_new/misc/tech_center/install/6000/60229.pdf
Page 2, Section 2, Paragraph 1 and Figure 2.
D
D.Hearne
11,730
south louisiana
Sep 12, 2008
  • Sep 12, 2008
Read 65fastbackresto's post above. No need to tear the short block down to drill the holes. If it's on an engine stand, just rotate the block to where the deck is facing downward somewhat and drill away. As for the comp ratio, you need to do several things to make sure you get it there. First is determine the deck clearance of the piston tops at TDC, if they're not right up at zero deck, you may need to mill the heads to compensate If you got the 64 cc heads, they will have to be milled to get you anywhere near a 9.5 to 10 to 1 ratio with a 289 crank
65fastbackresto
1,229
AR
Sep 12, 2008
#10
  • Sep 12, 2008
  • #10
I just dont want this guy
to go thru what I`ve been thru with this steam hole issue. Our county fair parade is tommorow and I cant drive my car in it cause of this problem.
65FBE2
283
Minnasnowta
Sep 12, 2008
#11
  • Sep 12, 2008
  • #11
As far as the bolts go. This may seem to easy but all I did when converting to 351W heads(same 1/2" hole in the head) is drill and tap the block from 7/16 to 1/2. Now I use 1/2 ARP bolts and have much better clamping of the head to the block with out any bushings. I would assume you are getting new bolts anyway. The project takes less than an hour. Use a 1/2" thick block of anything with a 1/2" hole drilled in it to guide the tap striaght
I also agree that 2.02 valves are overkill on a 289 unless it is highly modifed. You will loose intake volositcity and therefore give up bottom end power
iskwezm
4,159
20
79
Rowland Heights,California
Sep 12, 2008
#12
  • Sep 12, 2008
  • #12
I had them on my 289, and lost compression,the valve springs do not handle lift up to .575 like it claims and I woish i woulda got AFR's but they werent available(about 14 years ago)
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Resolved Need help!! 289 with 351 firing order issues
  • Falcon67
  • Jun 13, 2024
2K
1965 - 1973 Classic Mustangs -General/Talk- Jul 6, 2024
2Blue2
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Progress Thread Komo's 1990 GT - Parts Gathering Purgatory & Home Remodel
  • gkomo
  • Sep 23, 2024
  • 103 104 105
2K
78K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 9:40 AM
gkomo
