I finnaly got the stang(65 GT) back on the road and got to fully test it out(new motor,had to let it break in).It seems like its got a lack of power for whats been done to it.I dont have any dyno numbers or track times.Iv been told by a few other guys that a demon or holley would run better than my edelbrock 650.I talked to the guy I bought it from and he said that it seemed like when he put on that edelbrock it didnt have as much go.I wish I had some numbers to post so I could get some good opinons if its about right.The motor is a .040 302 with hyp. flat top coated skirts pistons,total seal gapless rings,high volume oil pump,double roller timing chain,comp cam 280H(280/512) hyd.,comp cam hyd. lifters,comp cams 1.6 roller tip rockers,comp cams double valve springs,vavlve shims,viton valve seals,1968 351W heads,edelbrock performer intake (no not a rpm),edelbrock 650 carb,mallory unilite distributor,mallory 8.8 wires,ford motorsport coil,stock manifolds,h pipe,crappy mufflers(P.O. had "super turbos" put on), and stock tranny.
) and either get a jet kit for your 650 and jet it, or get a Demon that will satisfy your cams needs.
