  • 1994 - 1995 Specific Tech
Edelbrock Performer 2 on 95GT?
  • Thread starter Thread starter Colinhamid
  • Start date Start date Feb 24, 2008
C
Colinhamid
  • Feb 24, 2008
Has anyone installed Elelbrock Performer 2 intake on 95GT experienced Hood clearance problems? Any noticable gains in power? Is it worth it?
Engine has less 60K miles no other engine mods Ford Motosport headers and BBK cold air.
earleys94gt
1,223
Ashley, Ohio
Feb 24, 2008
  • Feb 24, 2008
I assume you mean the RPM II.
On a stock engine an intake like that, which moves the powerband up in the RPM range, will cause a loss of some low-end torque in exchange for upper RPM horsepower.
As for the hood clearance, I can not say.
If you do a search, you may find some more complete answers. Good luck.
And welcome to :SNSign:!
HGFireHazard
460
Michigan
Feb 25, 2008
  • Feb 25, 2008
If you're talking about the RPM 2 (which has a listed powerband from 1,500-6,500) than I would shy you away from it with the mostly stock motor.
An intake is a good upgrade to get but you may be better off looking for a set of heads for the price of an intake (unless you find a good deal used)
GT40s are a good lower budget idea, and there are other intakes that would suit those heads (and your E7's) better.
mootang
907
texas
Feb 25, 2008
  • Feb 25, 2008
like mentioned above it is a good intake but with a stock engine it will probably be a bit of over kill.
Dino Dino Bambino
1,673
90
79
Cyprus
Feb 25, 2008
  • Feb 25, 2008
Ditto. Not a good idea to install the Eddy RPM II intake on stock E7 heads. I would only use this intake on better-flowing aluminium heads like Edelbrock's own Performer items, the AFR 165's, the Holley Systemax's, or the TFS Twisted Wedges. The Eddy RPM II intake is also recommended for the E7 Power heads.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 26, 2008
  • Feb 26, 2008
I'd choose that intake in a heart beat
IF ... future plans supported its use ... that is
No way in the world would I buy two intakes
if money is any kind of issue ... which it usually is ... for most of us
Yes ... as all have said "It is not the best for how he NOW is equipped"
BUT ... if he has plans for good flowing heads and a nice cam later on ....
Buy the right intake now for those other parts later on so you don't end
up with the wrong intake and have to sell it for a loss to obtain a intake
that is more suited for what the long term plan is
As always .............
A plan needs to be in place for one to be the most efficient :Word:
and
The plan should based upon application
In this case ... that intake is bad for now
but
Could be good for later on
Grady
fastgtfairlane
266
  • Feb 26, 2008
i would get that intake in a heartbeat. even on a mostly stock bolt on engine. sure your gonna lose a little bit of low end torque but the gains in the midrange and topend will be way better. i have a typhoon which its powerband is 1500-6500 rpm and love it. just run a little steeper gears to compensate. then once the heads and better cam come in you will be that much better off in the long run.
HGFireHazard
460
Michigan
Feb 26, 2008
  • Feb 26, 2008
I think most of us can agree that the RPM 2 is a good intake if he has future modifications in mind, specifically heads and a cam, but we can't be sure of that.
OP, if you don't plan on a set of heads and a cam than there are better intakes for you at this point in time. However, if you do wish to put heads and a cam on later, do you have an idea as to what? We can give you a little better direction depending on what your future plans entail.
StinkinLincoln
240
Louisiana
Mar 4, 2008
  • Mar 4, 2008
to answer your original question, yes it will fit, or maby not.
i had to put 2 washers under my motor mounts to keep my bbk equal shorties from hitting my steering shaft, that raise the motor 1/4in, just enough for the hood to hit, its closes but part of the intake hits the hood, i will trim part of the brace out so that it doesnt hit, then it will be all fine.
For Sale 1999 Ford Mustang GT Convertible 2D - ProCharged - 434 RWHP
  • Brynden29
  • Nov 12, 2026
SN95 Mustangs For Sale (1994-04) Nov 12, 2026
Brynden29
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
