Do the ports match up correctly? I assume they would. I have gotten recommendations to go with the RPM II over a Trick Flow Intake for my 347, which has Trick Flow heads. Let me know if it will work properly and also what the best intake would be for a 347 making around 375-400 to the wheels. Thanks!
I guess my options are Trick Flow Track Heat, Trick Flow R series, and RPM II. Which would best suit my needs with Trick Flow heads?
) with unported trickflow heads and a custom FTI camshaft. I use a TFS R manifold. I've never dynoed mine but I would say this combo should be good to around 6,700 rpm. My heads are milled to 55.6cc. It depends on the entire package, but that 2031 cam will get lost in a 7000 rpm 347. I'd go custom or an AFM n91 or n111 hi rev cam.
So there will have to be some things redone. I may just buy a Dart block or something and start over with it and use the TF heads....
