I am probably going to have to get a new fuel pump. The stocker will probably not cut it with 36lb injectors. So, I am trying to weigh my options.
Who makes a drop in style fuel pump for an 04 GT Fuel tank? I have heard I can run a walbro gss342 (255lph) in my gt tank with the returnless setup. I know that the aeromotive 340 lph stealth pump (11142) will fit as a direct replacement to a walbro 255 lph. So, other than drilling some holes in my basket, do you think I will run into any issues with anything else?
I am a little uneducated in fuel systems, and I am trying to learn as I go.
As much as I would love to run a return style setup, my budget will not accomodate that. So, I have to come up with something that will work, and still not break the bank. So, realistically, what can I do for under $200. I am currently running a boost-a-pump on stock fuel pump w/ kb 36 lb injectors. Cams are going in when they get here, and the tuner said that the injectors will work if i can get them enough fuel. What do you guys suggest?
I've got 36# injectors and the OE pump is doing fine with a BAP.
