Efi Conversion!!!
  • Thread starter Thread starter 67staaang
  • Start date Start date May 30, 2005
67staaang
132
  • May 30, 2005
hey guys i found an EFI dist out of a 89 mustang gt. do you think it will perform good enough?? how could i tell if i could use the dist with my cam or not?? what fuel pump do you guys recommend for my EFI conversion?? also what fuel filter do you guys recommend too? i could use all your guy's knowledge about EFI conversions thanks for your helpful ideas and comments!!
T
TT670
360
9
28
May 30, 2005
  • May 30, 2005
That distributor is for a roller cam, it'll have a steel gear, if you choose to use it on a non roller cam engine you'll need to change the gear, no biggie. For EFI on a mild engine Ron Morris performance and mustangs plus sell a decent pump thats reasonably priced, its a stock external ford pump. If youre making 350hp or more its not really enough pump but its perfect for most efi conversions, and can be used with a ford EFI filter OR an aftermarket. check it out www.ronmorrisperformance.com Ron seems to be a great guy and will help his customers with EFI conversion troubles whenever he can.
67staaang
132
  • May 30, 2005
thanks for the info TT.!! hey TT670 how many MPG are you running at right now?? wiht your EFI system? i have a 289 and i jus want to know about where my MPG will be around. thanks
67staaang
132
  • May 31, 2005
how many MPG do you EFI stang people have??
Hack
1,945
Minneapolis
Jun 1, 2005
  • Jun 1, 2005
Isn't the firing order going to be different between a modern and classic 302 as well?
67staaang
132
  • Jun 1, 2005
eh?? naw i believe the firing order is the same. but what does that have to do with classic EFI stangs MPG?
T
TT670
360
9
28
Jun 1, 2005
  • Jun 1, 2005
Hack is right, Im glad that was brought up. If youre using EFI from a 5.0L HO motor, its a sequential fire system and it requires the HO(old351) firing order. Dont fret, you can change some wire locations in the 60 pin connector and straighten that out if you so choose or If youre going to upgrade cams get one with the 351 firing order. The 60 pin wire changing info is also on www.fordfuelinjection .com. If neither of those sounds appealing you can get a batch fire EFI system from a non HO car and it'll be fine. I suggest the HO Sequential EFI and changing the wires in the 60 pin..its a better setup and its easy to change.
Tubo(2-bo)
279
Ft Walton Beach FL.
Jun 1, 2005
  • Jun 1, 2005
It's my understanding, that sequential injection on an early firing order engine will perform as batch fire. Idle isn't quite as smoothe.
Looking for a high-res photo or scan of Rotunda EEC-IV Overlay #17 or #23
  • Smokinjoe 33
  • Jul 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 21, 2026
Praetorious
P
H
Fuel starvation issues, 91 EFI to carb swap. Car dying after 1-3 gallons used. EFI tank, electric fuel pump, bypass regulator. Dual fed carb
  • hassler
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 12, 2025
nickyb
T
1979 foxbody in tank fuel pump
  • Tgm624
  • Sep 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2025
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
