I agree with much that has been said about switching, especially Lamrith. I just made the switch from EFI to carb and I am not yet running as well as I was. However, I have no regrets as I am confident I'll get there. Here is the best generalization I can make: The closer your car is to a race car, the better off you'll be with a carburator. Due to the long-runner intakes, I am convinced that you can make more torque with the same long block using an EFI setup, but you will be rpm limited. When that limitation becomes a impedement to performance, it's time to switch. If your car is a daily driver that you race, stay with EFI.
In my case, the car is a toy that I race. I can change the combo far more easily with a carb. Having said that, I also agree with "GoSpeed.." Don't switch to solve a problem as you are going to encounter new problems when you switch. I did. The switch is a time consuming and expensive process.
peace
