EFI to carb?help..
DJZSTANG1
FL
I am in the process of doing a efi to carb swap setup in my 91gt . I have a motorsport converted carb dist. Do I need a duraspark ingnition box if I have a msd 6al? and does anyone know the wiring set up ? thanks Dj
my dist has black with orange ..and two soild blacks that come out of it. found out that blk/orng = purple and one blk is taped off the other is the green... so that is like you said simple..lol now do I need the duraspark ign. box to make it work? msd's site is tellin me this ... on coil side of msd 6al
blk to - side of coil
orange to + side of coil
white ..taped off not used
red to????? it shows a horse shoe shaped connector with TACH and C+ on it and shows the red wire going to the C+...What is the C+?????
if thats a duraspark dizzy just treat i like a normal msd dizzy for wiring. purple being the same but fords is orange instead of green. look under the rotor the 2 wires should be going to the pickup and the third black wire will be grounded inside the dizzy. no duraspark module needed
