  • SN95 V6 Mustang Tech
egr flow insufficient
  • Thread starter Thread starter mjw
  • Start date Start date Jun 29, 2010
M
mjw
  • Jun 29, 2010
I have a 2000 mustang manuel and am getting code P0401, egr insufficient flow. i am also getting lots of vibration through the shifter from about 1400 to 1700 rpm and hesitation when accelerating. i took it to a local shop who told me it needed a new dpfe sensor which i replaced but it didnt fix anything. any help or ideas would be appreciated.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 29, 2010
  • Jun 29, 2010
For this particular DTC it can be a PIA to track down. About equally it can be the DPFE, Clogged/rotted EGR valve, the vacuum lines to/from the DPFE.
Since you have already bought a DPFE, recommend inspection of the vacuum lines to/from the DPFE. Any leaks can cause this DTC.
The post does not state the mileage of the car. If high mileage, this could be caused by carbon build up blocking the EGR flow through the throttle body. Consider cleaning the throttle body EGR passage ways.
Also, if high mileage, the EGR valve itself could be bad. If if were my car and 100K plus miles, I would replace it at the same time I cleaned the throttle body.
M
midnightrider_s
  • Jul 6, 2010
mine had a broken vacuum line at the egr valve
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
'04 V6 running rich excessively on both banks
  • 04DSGVert
  • Oct 26, 2025
SN95 V6 Mustang Tech Oct 27, 2025
04DSGVert
