EGR plugs for back of heads
88mustng
76
NJ
i wanna take off the pipe that connects the 2 heads for egr.
does anyone know the ford part# for this. also is it just bolts that screw into the back of the head or is it somethign else also??
hopefully if i can get a part number i can see a pic of what i would be getting and maybe make something.
thanks, steve :flag:
That's not for the EGR, that's for the Air Thermactor Pump. EGR comes up from the center of the head through the intake to the EGR valve. Trick Flow sells the plugs, and Stang22 is right, Ford might have them.
Why dont you just go to a jy and buy the tube. To make your own block off all you have to do is cut the "blocks" off of each end, then flip them over and swap sides. Then with a little of the high temp rtv, just bolt them back on.I would show you some pic but it is on the car and you can't really see it all that good. I do hope that this helps.
Nate
