Helping a buddy out with this.... When the car is cold, starts right up and idles fine. Once the car is shut off and restarted, it will not idle at all and will shut off 9 times out of 10. If a constant vacuum line is hooked to the EGR, it idles perfect every time but sounds like it is misfiring and the car jerks driving down the road at a steady rpm and also takes an extra 5 seconds before the car will start when cranking it. Tried replacing idle air control valve and adjusting fuel pressure, tps, and idle which made no difference. Cleaned all electrical connections, mass air, etc, and checked for vacuum leaks. Any ideas to help get this problem fixed would be a great help......
Larry
Larry
