Egr Question?
Also if I don't have a smog pump would it be any use buying the egr and everything that connects to it?
It is evident that either you didn't read my post about EGR operation, or didn't understand it. Which is it?
There was a complete description of the EGR system and a vacuum diagram. Look closely at the EGR diagram and you will see that there is no smog pump in it.
Found this online I see the white vacuum and black line beside the egr goes to the egr and to the back of the intake.What are the other 2 lines for? Where can I get this block and lines at?
Sorry I don't think I understand it. I don't see where the little vacuum block comes into play? Isn't that what hooks up to the egr?
The idea is very simple; look at the starting point and end point for the vacuum lines and connect the two points together with vacuum hose. Whatever you have inline connecting the sections of vacuum hose isn't important as long as it doesn't leak.
