EGR Similator
  • Thread starter Thread starter slow5.0gt
  • Start date Start date Jul 3, 2007
slow5.0gt
138
  • Jul 3, 2007
Anyone tried this yet to elminate the CEL?
http://cgi.ebay.com/ebaymotors/87-9...020QQitemZ300126021702QQrdZ1QQsspagenameZWDVW
cenok is family
1,409
69
79
Norman, Ok
Jul 3, 2007
  • Jul 3, 2007
by the looks of the customer feedback, it seems to work
D
Deleted member 87397
Jul 3, 2007
  • Jul 3, 2007
Why do you want to eliminate it just out of curiosity? Is this car daily driven or a track vehicle. The EGR system causes very very minimal power loss if any, reduces harmful emissions and gives you better gas mileage.
98BLKGT
322
Chicago area
Jul 3, 2007
  • Jul 3, 2007
You could probably just take off the EGR valve but leave the sensor hooked up somewhere behind the intake. I think the EGR sensor is about as big as the eliminator. Just make sure the sensor rod is not pushed in.
slow5.0gt
138
  • Jul 3, 2007
Well when I got this car the previous owner had attempted to remove the egr system disconnected and/or cut the vacuum lines. Egr sensor is gone so thats out of the question.
If i just use a stock sensor but its not hooked up wouldnt that however still throw a code?
98BLKGT
322
Chicago area
Jul 4, 2007
  • Jul 4, 2007
Having a stock sensor hooked up without the egr valve should be no different then having the EGR with the vaccum line disconnected.
When the EGR vac line is disconnected the computer senses that the egr is not opening therefore it does not take it into consideration.
M
MustangOwner
Banned
Dec 13, 2006
160
  • Jul 4, 2007
haha thats what they want you to think! ha idk it might work?
Personally my engine is getting dynoed in 3 weeks and i'm deleting smog and egr and its a full blown street car. So there gonna tune it and evreything so its off. Dyno tune is 200.00 bucks around here!
G
getusummm
156
  • Jul 4, 2007
Here is link on how to DIY. simple resistors from radio shack. it says 94-95, but the 93 down are the same. http://www.mustang-tech.org/wiki/Image:EGRDelete.jpg#file
93 LX
3,081
Norwalk, CA.
Jul 4, 2007
  • Jul 4, 2007
It looks like it is the resistor thing just in a nice package. If you have some soldering background then build one but if not then get this. Hell its 20 bucks, whats that buy these days? 1/2 tank of gas?
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Jul 4, 2007
#10
  • Jul 4, 2007
  • #10
Mine is blocked off at the heads but the EGR is still there. Thanks for the tip, I'll try that resistor thing.
98BLKGT
322
Chicago area
Jul 4, 2007
#11
  • Jul 4, 2007
  • #11
Did you block it off between the heads and the lower intake? I'm in the process of putting my intake back on and I should do that since I dont have the EGR stuff.
Any special way of putting those little gasket pieces on? Did you have to use any RTV?
Mustang5L5
Mod Dude
Feb 18, 2001
43,360
18,106
224
Massachusetts
Jul 4, 2007
#12
  • Jul 4, 2007
  • #12
Why does everyone want to remove the EGR for?? It does nothing for performance. Unless you get a custom tune to readjust the part throttle fuel curves, you will run lean during average driving around RPM.
The resistor does work, but the bigger issue is getting a tune when you remove the EGR...and not many people do this.
Reactions: jrichker
A
agent wd/40
North Carolina
Jul 4, 2007
#13
  • Jul 4, 2007
  • #13
pull the vaccum line of the fuel pressure regulator plug the vaccum line you will have 42lbs of fuel pressure and theres your custom tune. lol
ninety15.0
1,336
#14
  • Jul 5, 2007
  • #14
I have noticed a lot lately that people are confusing the EGR and Thermactor/Air pump systems. The EGR on our cars is internal and the Exhaust gas rises up through the center of the U/L intake. The two pipes behind the heads are solely for the thermactor/air pump system and those pipes coincide with the bumps in the exhaust ports of the heads. They are often misnamed but they are thermactor bumps and have no relation with the EGR system!. I see a lot of threads about EGR delete and what not...but most people are not familiar with how these two systems actually function. EGR delete on a street car is worthless...especially if its not done correctly. It must be turned off the in the computer.
stoksuks
#15
  • Jul 6, 2007
  • #15
Will having a disconnected egr cause any driveability prob?I just figured out my solenoid valve was missing & wondering if this is what was causing my slight bucking while cruising
90_Red_LX
668
Asheboro, NC
Jul 6, 2007
#16
  • Jul 6, 2007
  • #16
When the computer sends the signal to open the egr, it cuts the fuel back to compensate for the burnt gasses reentering the engine, since it's not fresh air. Nothing that I would want. Disconnecting EGR is retarded without a tune, and even then I doubt I will drop myn.
myslo50
247
ohio
Jul 6, 2007
#17
  • Jul 6, 2007
  • #17
i bought on off the net and currently am using it on my car now. works great. removed the egr all together and installed a blockoff plate looks nice and clean too. the part took about a week to get. tucked it behind some wires so u cant see the eliminator.
Hughes
11
Sedro-Woolley, WA
Oct 12, 2014
#18
  • Oct 12, 2014
  • #18
Mine didn't work on 95gt. Got a code of low vacuum pressure to egr now the car hesitates going down the road. I eliminated mine because the exhaust tube going to the headers was stripped cracked and leaking.
2000xp8
SN Certified Technician
Aug 8, 2003
8,068
1,654
194
NJ
Oct 12, 2014
#19
  • Oct 12, 2014
  • #19
I used that egr simulator for years.
Worked fine.
Has no positive or negative effect on how the car runs.
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Oct 12, 2014
#20
  • Oct 12, 2014
  • #20
I used it for years on cars and it works fine. Just got a tune when I did my HCI so he took care of the EGR delete at the same time.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
2K
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
  • dan50
  • Jul 18, 2026
dan50
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
