EGR Spacer Gasket Blowing Out One After Another..HELP!
  • Thread starter Thread starter 92GreenGT
  • Start date Start date Aug 22, 2004
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Aug 22, 2004
  • Aug 22, 2004
Guys, I have a problem, my car is eating up EGR Spacer gaskets like cookies. I know this isnt normal at all. I put an inline breather over to the air filter. I also took the off the oil filler breather and replaced it with a regular cap. I think I should have put a breather and the inline filter. I dont know whats my problem, I have NO DAMN CLUE whats causing this. Can you block off the the Coolant flow through the EGR Spacer and be alright still? Looks like im off to buy yet another set of TB gaskets. This is going on my third set. If you have ANY type of answer, please let me hear it.
Dave
R
ratrapp
510
buena vista,va
Aug 22, 2004
  • Aug 22, 2004
you can bypass the coolant lines if you want to,just unhook the 2 hoses and put a small piece of pipe to connect the hoses together.there are other ways to bypass it but this is the easiest way.is it blowing coolant of it or just causing a vaccuum leak?
TT91
1,536
Paramus, NJ
Aug 22, 2004
  • Aug 22, 2004
bypass is, use rubber nipples.
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Aug 22, 2004
  • Aug 22, 2004
So I can do that no harm? Coolant is dripping out of the bottom of the gasket between the TB&EGR Spacer. So I can just buy new gaskets and hook the two lines together then put two plugs over the two lines sticking off the EGR Spacer no problem?
Thanks
Dave
Rick 91GT
Mustang Master
95
99
PA
Aug 22, 2004
  • Aug 22, 2004
Thanks
Dave
Yes, very easy to do...
If those gaskets are leaking I would lean towards a bad seal when you put it together, the surfaces have to be very clean...
9
92GreenGT
PEAT
2,085
Big Stone Gap, VA
Aug 22, 2004
  • Aug 22, 2004
Yeah thats what I was thinking too. I cleaned it good both times I put the new ones on though, hard to say to tell the truth. But I will fix it again, right this time.
About to bite the bullet, and get me a newer style stang. Keep the green monster though, let Rick build me a beast.
Dave
Engine Sick of stock TB and EGR spacer...
  • 91GTstroked
  • Dec 15, 2024
Fox 5.0 Mustang Tech Dec 19, 2024
General karthief
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
A
Resolved 1989 Mustang bogs down after 3-5 minutes of driving.
  • Alabama
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech May 26, 2025
limp
Engine Coolant leak from throttle body
  • 91GTstroked
  • Oct 9, 2023
4K
Fox 5.0 Mustang Tech Apr 27, 2024
91GTstroked
