eibach drag springs
Did they start making them for our cars? I hadn't seen them for our cars.
When I bought mine, I asked the guys what would be the best spring for a daily driver that will see the track frequently, and he said the Eibach Pro Kit. And I'm happy I took their recommendation. Between the springs and D-Specs, I get virtually no squat on launch.
I may try those myself. I didn't know they made them for our years either...no they don't lower the car and on the fox style cars they seem to make the front sit a bit higher but I think our cars are heavy enough to where it would probably just look like stock ride height...good find:nice:
Thanks for the link.
I run full hard in the rear and full soft up front. This is what my launch looks like. In this picture I'm lowered with 28" tires. Looks like it does sitting still, except for a bit of lift of front.
thats a great picture. how high are you launching at?
i see mustang and fast fords got a tire up a few inches on their 12s or bust article. do you still have your front sway bar on?
are you running radials or slicks on the stockers?
and i didn't think they lowered at all, just wanted to make sure. does the air bag really help at all? i couldn't find any information on the reasoning behind it, i know a little on what it does, but i figured if it worked great why isn't there more information out there.
how does it inflate?
Swaybar has been deleted and installed BMR lightweight radiator support. My suspension setup keeps the front end from popping up and the rear squatting. As you can see, the front comes up a bit, which helps with weight transfer. The front tires should come up until 10's, or low 11's, on a properly set up car. And even then, you can stop that. It looks cool, but you're loosing energy most of the time. A 12 second car, properly tuned, should not bring the front end up more than 3 inches or so. If it brings it up more, it's probably squatting, which is losing energy. Not lowered means that they were running the stock springs. Stock springs are crap for drag racing.
I'm running drag radials. I was running M&H 325/45/17 in that pic. That launch was at about 4k.
I'm not sure how that inflates. I would assume probably a hand pump or something. From the desciption, it sounds like it's the Pro Kit springs plus the bag. The bag is just to keep the rear end from sagging on launch, which wouldn't happen probably until 11's. It's not near the issue on our cars that it was on previous generations.
oh i know getting the front end up is hurting a little bit but i think it'd be cool to say that i lifted a tire off the ground.
yeah, i thought it was odd it only came with one bag for the pass rear, alot of the kits i see with bigs are one for both the back ones.
Mustangs tend to squat more on the passenger side, thus the reason for the one bag. If you look at pictures of SN95s and Foxes pulling the wheels, you'll usually notice the passenger side is squatting more.
No HDR on this one? lol. How well do the 325s fit in the wheel wells?
Nope, no HDR. That was point and shoot taken by my wife. Not to mention it's nearly impossible to get a true HDR with an object moving that fast.
They fit great. At stock height, there's still quite a bit of room. With 1-1.5" lowered, there's still an inch or so, and with the right wheels, they'll tuck if you hit a bump. It was very nice of Ford to roll our fenders from the factory. Just make sure that if you're lowered, you have an adjustable panhard bar to get the rear end centered.
this is right after I lowered it, so the springs hadn't settled yet.
Yes, the springs definitely settled. That picture was 10 minutes after installation.
The rears on the image above are about the same height as this one. These images were a couple of months apart. I wish I had a better "right after" and "after settling", but after lowering and getting new wheels, I put drag radials (shorter than stock) on my stock wheels, so it wouldn't be a fair comparison. The initial lowering lowered it about an inch. It settled another half inch or so, to the advertised 1.5". Also, the front tires are wider, but the same diameter as stock, and you can see the difference there as well.
