Hi, is any one running the eibach drag springs? I have eibach sport rears an i'm lookin at some drag fronts now...do they lower the car any an how do they handle? thanks for any input.
If your going to go with drag springs I would think you would want the full set of 4 to be drag springs. They are designed for max weight transfer so the front will come up really hard and the back will squat really hard to get all that weight on the rear tires. Not running the drag springs in the back might defeat the purpose of having them at all.
I have the full Drag Shock set up with the airbag and lakewood drag shocks. With this combo the front end is way up in the air. Dont know if it would be less pronounced with standard shocks. Suck for road course - straight line only.
We used the Eibach with the air bag. They do give you a bit higher stance. I would use all 4 drag springs not just the front. Thats how they are designed. Also as far as handling, they are designed for straight line not so much for handling. With everyday driving, you aren't gonna see that much difference in handling.
