  • SN95 4.6L Mustang Tech
Eibach Pro-System Kit
  • Thread starter Thread starter Mr GT 02
  • Start date Start date Feb 18, 2006
1 of 2 Next Last
Mr GT 02
548
Peabody, MA
Feb 18, 2006
  • Feb 18, 2006
I plan on getting this kit from www.maximummotorsports.com
seems like a kit that I am looking for. My car is mosly a Daily Driver with the occasional strip trips.
Anyone with that kit? ya like it?
steveb24
555
wilmington, DE
Feb 18, 2006
  • Feb 18, 2006
i got the h&r super sports..not yet installed..i thought about the pro-kit but then it just dosent look low enough..mines a daily driver too..and the diff between super sports and pro-kit isnt that much anyways
03GTconv
49
Fort Worth
Feb 18, 2006
  • Feb 18, 2006
The pro kit is what i got and theres still around 1 and 1/2 inches between tire and fenderwell, it looks good but yeah it could go lower
reddrgn01gt
161
Pittsburgh, PA
Feb 18, 2006
  • Feb 18, 2006
I have that kit on my dd and i really do like it. It is lowered nicely and the ride is actually better than stock imo. The car handles much better also.
Cantslowdown
502
Mt.Home AR!
Feb 18, 2006
  • Feb 18, 2006
I am looking into getting a set of spirngs i was thinking about going with the ford motorsports springs..
reeber
574
26
38
Berlin, NJ
Feb 19, 2006
  • Feb 19, 2006
I have the pro-kit springs and shocks.. no sway bars... here's a picture of my ride height... The car actually rides much better... less body roll, less squat, and even takes the bumps in the road better... Then again, I am comparing it to 9 year old stock shocks!
Mr GT 02
548
Peabody, MA
Feb 19, 2006
  • Feb 19, 2006
lookin good!
jrc_03_gt
786
  • Feb 19, 2006
here is mine with pro kit springs and pro dampeners the swaybars did not fit they rubbed my wheels. I am very happy with the springs and shocks though.
Mr GT 02
548
Peabody, MA
Feb 20, 2006
  • Feb 20, 2006
are u using the stock spring isolators? or did u need new ones?
hognutz
1,940
albany, oregon
Feb 20, 2006
#10
  • Feb 20, 2006
  • #10
I would not buy the kit. swaybars are not nessesary. there are better springs I think. search for threads about sagging eibach springs. then search for thread about sagging h&r springs. you will find more people complaining about the eibachs.
I mean everbody gives a thumbs up to what they have. I did not buy eibach based on the number of people posting long term issues with there stuff.
for the money of that kit you could buy a better setup.
every mustang needs subframes and LCA's to handle well at minimum. with the kind of money that system cost you could have those.
shocks and struts make it handle better but your car will still handle poorly without something to reduce flex and locate the rear axel better.
for the money of that eibach system you could piece together a kit that would outhandle it going away with just as good if not better street manners.
Mr GT 02
548
Peabody, MA
Feb 20, 2006
#11
  • Feb 20, 2006
  • #11
Well I already made the decision and ordered the kit.
2002tj
Houston, Lone Star
Feb 20, 2006
#12
  • Feb 20, 2006
  • #12
Like what...
R
Rosa
36
SoCal
Feb 20, 2006
#13
  • Feb 20, 2006
  • #13
Mr. GT 02,
The Eibach pro-kit springs are ideal for somebody who drives their car everyday. It lowers your center of gravity and reduces body roll. It reduces squat when accelerating and the nosedive when braking. It improves the handling and reduces that unwanted fender gap. They are progressive rate springs. Eibach springs are also guaranteed not to sag or settle. They are under a million mile warranty. You can also find competitive prices through online distributors.
An aftermarket shock would be the next step for further controlled ride quality.
And finally sway bars further reduce body roll.
I'm glad you decided on Eibach.
hognutz
1,940
albany, oregon
Feb 20, 2006
#14
  • Feb 20, 2006
  • #14
2002tj said:
Like what...
well there a million ways to do suspention. people like different brands etc.
springs, shocks, subframes, LCA's (good design most like likely mixed bearing)
will outhandle the pro-system.
you could do ford springs, h&r, tokico makes sytems. shocks an struts there are mach 1 tockico's, tokico hp's, kyb.
then you on lower control arms you could do, MM, pro 3i, etc
subframes should be full length welded there are tons of different variations.
bottom line is springs, shocks, struts, and swaybars alone will not handle all that great. It will help but my car was still very loose in the rear at this point. I bougth bilsteins, h&r, MM CC plates so I had pretty high dollar stuff at this point. Once I did the LCA and subframes it was a huge step up again in handling.
I would bet that before I did the subs and LCA someone with cheaper parts but with the rear end issues fixed would have drove right around me.
hognutz
1,940
albany, oregon
Feb 20, 2006
#15
  • Feb 20, 2006
  • #15
it is not a bad product don't get me worng I just think some of the money is better spend eslewhere.
you add some suframes and some product to help the rear axle location and the car will handle awesome.
everybody just seem to dismiss some of the other products as gimicks or not needed for a street car. I kind of disagree. I mean my camaro came stock with panhard rod. so does the 05+ stang. they finally pulled there head out.
reeber
574
26
38
Berlin, NJ
Feb 20, 2006
#16
  • Feb 20, 2006
  • #16
There hasn't been one complaint about the Pro Kit sagging from what I've read and heard, but there are a lot of complaints about the Sportline... They are two different types of springs... Pro kit is progressive rate, when the Sportlines are one rate...
Mr GT 02
548
Peabody, MA
Feb 21, 2006
#17
  • Feb 21, 2006
  • #17
Rosa said:
Mr. GT 02,
Do u work for Eibach or suttin? lol
Mr GT 02
548
Peabody, MA
Feb 21, 2006
#18
  • Feb 21, 2006
  • #18
ohhh..just because I just got the springs and shocks/struts..does not mean i"m not gonna get other suspension stuf to in the future.
I do plan on the MM full legnth sub frame connectors..and control arms and all that good stuff...lol
I just dont have all the money now to do the WHOLE suspension yet...heh
hognutz
1,940
albany, oregon
Feb 21, 2006
#19
  • Feb 21, 2006
  • #19
maybe it is just the sportlines that sag I just see so many saggin eibach threads I though it was all of them.
hognutz
1,940
albany, oregon
Feb 21, 2006
#20
  • Feb 21, 2006
  • #20
yeah that is why I did mine is pieces as well. yeah make the control arms and subs a priority.
I got the springs and stuff one christmas and did the subs and control arms the next chirstmas. It made such a difference I just kicked myself for waiting.
1 of 2 Next Last
J
Power Wire Upgrade Question
  • jhaling
  • Dec 21, 2025
SN95 4.6L Mustang Tech Mar 23, 2026
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
  • Mindseye007
  • Aug 16, 2026
Mindseye007
