elec fan controller setpoint
rockyracoon
874
27
49
margate NJ
well I decided to let my controller run the SN 95 in low speed only.the way I have it set it is coming on at 215 deg and going off at 205*,im gonna wire the high side of the fan to a relay and a switch in the cab,and prolly use it when the A/C is on.
If I read you right, that's not a good idea.
You do NOT want high and load speed engaged at the same time. The fan ends up spinning at a semi fast rate and shortening the life of the motor quite a bit. Also, a decent sized relay should be used for high speed (esp if you ever switch the fan from off to high, which also is not real great for the fan).
There are several ways to get around this issue, but they require more relays and wiring.
If funds allow, a Dc Control unit would be the way to go, all the way around.
Good luck.
rockyracoon said:
OIC.how about the setpoint temp is that too hot to have the fan start? I thought I read in another post that 215* was good.
What temperature t-stat do you use? It did seem a little hot to me (almost no matter what - even for a stock stat), but I figured you had a reason for that.
If you have a 180, I'd have it come on at about 197-200 and off at 187* or so. This will depend upon your thermostat (some dont open with much precision, nor are they consistant under differing conditions).
Good luck.
rockyracoon said:
im running a 195* stat.Should I have it come on a little lower that 215*?
You could probably try something like on at 208*, off at 200*. This would be what the factory used for low speed on the 94-95's, and it's about as low as I would go - you dont want to run it down so far that the fan always runs (in case your stat is a little slow to open).
Just MHO.
Good luck.
Ok I just readjusted it and thats pretty much where she is.On at 209* off at like 199*.as I said I just have the low speed of the fan hooked up and the 25 amp inline fuse is fine.when the a/c is on the controller keeps the fan on all the time and the temp just stays at 208-210*.what im gonna do down the road is hook up a 3 way switch inside the car and run one leg to the controller ,which only gives me low speed and hook the other leg up to the high speed wire via a relay for when it gets really hot out and the a A/C is on.That way when I throw the switch it will be out of low for a second but hopefully will keep me from getting the initial amp spike if I started it up in low from the get go.
