Well it has a solid fan it right now so ill run a new wire for it. I don't want it to run on a switch I just want it on all the time when the engine is.It should be wired through a relay. The size of the wire depends on the amp draw from the fan. We can help if you post up a little more info on the setup you have.
Welcome aboard, btw...
Actually, it's easier if you just post the info and what aspects you would like help with.If you need any more information about it just ask.
They said this one is better than stock
