Hi, I posted a thread awhile ago with some questions. I have a 180 t stat. and just purchased a fan that I haven't received yet. A mark 8 electric fan. has a high and low setting. I learned that a good all around operating temp is 200 and was given advice to start at 195 on, 187 off. Anyways, so the relay kit that comes with the mark 8 fan comes with:
Instructions for 2 different configurations
5 Prong Relay
Female Relay socket w/ harness
Inline Thermostat switch
14 total feet of wiring
8 connections
1 Fuse Buss or Circuit Breaker (where available)
I haven't received it yet but should be here today or tomorrow. The fan is said to pull 2500 cfm on low and 4000 cfm on high.
The relay will allow the fan to turn on low when the Coolant temperature reaches 155ºF or turn the fan on low at start up and then to high at 155ºF. The screw in Thermostat switch can be replaced with a temperature switch of your choosing from a local parts store, if a lower temperature is desired. The set up was designed for Ford Lincoln Hi-performance two speed electric fans.
I would like to use both the high and low. So if the proper operating temp is supposed to be around 200 then I want it to pretty much stay within that.. I think I read somewhere that the water temp is usually about 10 degrees less then operating temp. Is that right? So if water temp is 190 does that mean the operating temp is probably around 200. So if I have the fan turn on high at 195 that would be trying to cool down the coolent once the engine hits 205 (195 + 10) should I set the low speed to 190 (operating temp 200)?? I'm a little confused. Is the 180 t stat measuring the fluid cooling in the rad. or engine the engine. Kinda confused... Doesn't seem right..
Should I put the 192 degree thermostate back in? Seems like that would be a good idea for emissions. Because a warmer engine burns up more of the fuel. I think the fan on low at start up to cool the rad fluid, then high at 155 sounds good. That is with the 192 degree thermostate. Because then when it hits 192 assuming that is measuring the water temp in the engine not the water temp in the rad then it will cycle the cool fluid. Should I leave it alone. What temp should the water be at for 200 degree operating temp 190 ish... ?????????
5 Prong Relay
8 connections
