At the end of last summer I did a Focus dual fan swap into my 93 gt. I used a cheap autozone dual fan thermostat kit. Ran the fan for very short time last summer before car went up for engine rebuild. This spring, start driving car and was blowing 30 amp fuses. Checked all wiring, no shorts and resistance was good. Eventually put a 40amp fuse in and had no problems. Been driving for a month like this.
Today, 80+ degrees and 45 minute drive. Started smelling burning plastic, fan stayed on when I pulled into garage and turned car off. Tapped on relay, fan turned off. Pulled relay, melting around #30 pin, which carries the main power from a 10gauge wire.
I know these fans pull alot of amps, apparently 30+ amps. The relay has the markings "12VDC 40/30A". I assume this relay is supposed to be good for 30 or 40 amps. Is this right? I don't believe the 10 guage wires are being overpowered, and the 40 amp fuse is not blowing. Do I need to upgrade to a true 40amp fuse? I know there are really nice controllers out there that are highly recommended, but the cost is an issue at the moment. Maybe not at the end of the summmer, but right now it is.
Can I put a 40amp relay in and drive, or do you think there is another problem here? I would think the 10gauge wire would melt or get really hot, or the fuse would blow if they were the weak link. I am thinking that the relay is the weak link here. Any ideas?
Thanks!
Thanks!
