I just wired in a 3.8 Taurus fan, am VERY happy with the
results.
A control that's similar to the DC Controller but I believe
a little less $ is the (new?) Flex-A-Lite soft start, variable speed controller.
After some research, I found that a Taurus fan pulls about
33 amps on high. There's a popular magazine article about installing one that has some incorrect info - it's actually a reprint of an earlier article installing a Mark8
fan which draws more, with some of the wording changed.
Anyway - after inquiring with FAL cuz the info in the Summit online catalogue was a little unclear, I found I needed the larger of the FAL controllers - just under $100 on Summit. Will handle 40 amps continuous. No relays needed with it.
You can see a good instructional on it at the Flex A Lite site, check out Automotive, Electric Fans, Accessories, and it will go to an Install article.
It soft starts to avoid the amp draw spike, is variable speed so the fan runs at varying speeds depending on how much warmer the motor gets than the ON setting you set.
You hook it to the high speed side of the fan motor.
You can add switches to completely shut it off, or to run it in spite of the motor temp. I added an LED in my dash to show when it's running, per that article above. When you start a warm engine, it delays starting the fan for 5
seconds to avoid a double draw while the starter is turning the motor, and will run the fan after you shut the motor off to cool the coolant in the radiator down to your "ON" setting.
FAL customer service was VERY good to work with, too.
