electric fan setup ideas
jgfiveoh
102
Topeka, KS
i did a search in tech for this but i was a little more interested in building a custom setup. i want to build a custom aluminum low profile shroud and mount 2 low profile electric puller fans side by side, but sort of offset from top to bottom. the one on the drivers side being lower and one on the opp. side being higher b/c my tranny cooler is on the lower drivers side of the rad. i would like to hook them up to temp controlled switches so i can have the main(drivers side) run most of the time and the aux only come on when the main one isn't cutting it. does this seem like a cool idea and do u even consider it plausible? also if any one has similar setups already or has any input or ideas let us all know. thank everyone.:SNSign:
Like this? These are dual 13" Spal Electric fans with 3420 cfm total airflow.
ya thats pretty much what i was wanting to do except i was thinking about staggering the fans. do u have a link where i could check those out. my rad. is still stock but i want to put on elec. fans that will keep it cooler in traffic. i've looked but i cant find a setup that like that (w/o alum rad) that's a direct fit for my stocker. plus i wanted the alum shroud look to clean up the engine comp. a lil. thanks alot for posting that and let me know if u have more info.
anyone else have anything to say or add?
is that a two row rad. with two 13"? cause i thinking of a custom three row rad. and a 15" flex elec. fan..
if this is more cooler then i think i'll go for this.. how much would it cost??
