Electric fan ????
  • Thread starter Thread starter mustangdaren
  • Start date Start date Mar 31, 2006
mustangdaren
605
Hildebran, North Carolina
Mar 31, 2006
  • Mar 31, 2006
Just wondering what electric fans you guys are using that have aluminum radiators (3 inch thick) and superchargers on their foxes? I was using a Ramchargers fan that I really liked and the motor finally burned out on it. I found they are out of business so I am needing another fan for the car. I only have 4 inches between the radiator and the s/c crank pulley so that knocks the Mark 8 and similar out. Any suggestions and installed pictures would be greatly appreciated.
Sicarius428
2,085
Mar 31, 2006
  • Mar 31, 2006
I hear that the dual 11 inch spals are really good and thin.
Kevin
04sleeper
2,674
14
89
Dallas, TX
Mar 31, 2006
  • Mar 31, 2006
SN-95 Fan with a Summit 31 X 19 radiator and Vortec YSI.
R
rflow50
172
TX
Mar 31, 2006
  • Mar 31, 2006
Taurus 3.8 fan, thats what i have with my setup.
mustangdaren
605
Mar 31, 2006
  • Mar 31, 2006
how much clearance do you have with the SN-95 and the Taurus fans?
mustangdaren
605
Mar 31, 2006
  • Mar 31, 2006
How did you mount it to the radiator? I have the Griffin Nascar universal radiator from Summit. Very similar to the Summit radiator you have.
04sleeper
2,674
14
89
Dallas, TX
Mar 31, 2006
  • Mar 31, 2006
Drilled 2 small holes in the top of the shroud and bolted it to the radiator using the factory clips and bolts.
Then on the bottom just drilled a small hole in the bottom of the shroud and used a fan strap (Kind of like a ziptie) to secure it to the bottom of the radiator.
Run with a Mr. Gasket 180 t-stat and it works like a champ!
R
rflow50
172
TX
Mar 31, 2006
  • Mar 31, 2006
The Taurus fan is about 3" inches thick so you should have an inch of clearance. I drilled two holes on one side of the shroud and used fan straps.
Brads Coupe
Sweeeeet!!!
2,838
Calgary , Alberta, Canada
Mar 31, 2006
  • Mar 31, 2006
I just purchased the new Black Magic Extreme for my baby.
http://www.flex-a-lite.com/auto/html/180_black_magic_x-treme.html
gruvee87vertgt
20+ Year Stangneter
Oct 7, 2003
272
26
28
Chicago, Il
Mar 31, 2006
#10
  • Mar 31, 2006
  • #10
sorry for the high jack......where can I buy the electronic fan thermostat controller? thanx
K.C.90gt
379
Detroit Area, MI
Mar 31, 2006
#11
  • Mar 31, 2006
  • #11
http://www.dccontrol.com/ check out their fans and controllers, i've heard nothing but good things about their products. A little pricey but will be worth it for the amount of money you have in motor. My old black magic wasnt enough to cool my stang.
hey can you let me know how you like that new fan from them? I was thinking about trying that out soon since it is supposed to flow better. THanks.
mustangdaren
605
Mar 31, 2006
#12
  • Mar 31, 2006
  • #12
I like the new blackmagic but it is too thick to clear my pulleys
04sleeper
2,674
14
89
Dallas, TX
Mar 31, 2006
#13
  • Mar 31, 2006
  • #13
Black "Tragic" and Flex-a-lite are no where near as good as OEM fans. The only company that makes anything even close is Spal and they do make some OEM fans.
Brads Coupe
Sweeeeet!!!
2,838
Mar 31, 2006
#14
  • Mar 31, 2006
  • #14
How is that? My rad is super thick, way thicker then a Fluidyne or a Griffin and I still have room, not much but it clears.
mustangdaren
605
Mar 31, 2006
#15
  • Mar 31, 2006
  • #15
My radiator is about 3.25 inches thick at the tanks, 3 inch at the core. Only have 4 inch between the S/C crank pulley and the radiator. I am thinking of either the dual spal electric fan or the Holcomb Motorsports dual 11 inch custom shroud and spal fans. I found the ramchargers fan through another dealer but they want between $135 to $175. I think that is a little much for that fan since they are pretty cheaply made and sold for $79 through ramchargers.
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Apr 3, 2006
#16
  • Apr 3, 2006
  • #16
Find the volvo fans on E-bay or on Corral(sometimes). I have put a few of those on blown cars and they fit great. The fan with shroud is only 3.75" thick. If you like e-mail me for pictures... mike84lx@knology.net
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
Exhaust April is the worst month
  • Enzio
  • Mar 4, 2026
1974 - 1978 Mustang II Talk & Tech Mar 7, 2026
LILCBRA
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
