This is the only picture I have currently. There is a positive wire coming from the battery and a black wire going straight to ground. There is one other red wire that goes inside the car. Is this an ignition hot wire? Where is the best place to wire this? And also, which way does the thermostat switch work? Farthest counterclockwise is 180 degrees?
I don't know what the brand of the electric fan is. It was hooked up by the red wire going inside the car and being wrapped around a fuse and the fuse jammed in, but I can't remember which fuse it was. I want to wire it up the right way to prevent any electric fires.
