Electrical Electric fans came on with car off...like a ghost
Mstng93SSP
You have a nice rear end there Dave.
3,500
184
Mililani, Hawaii
I have contour fans with a Derale DER-16795 controller. It has been on the car 2 years+. Today, out in the garage, not touching the car, no key in the car, have not driven the car since yesterday, and all of a sudden the electric fan came on at 100%. They would not stop. Had to disconnect the battery. I think the controller is fried. Anyone ever have this happen?
You are no dummy so I’m going to assume that on the controller you wired it correctly which would make me say it’s toast. As long as you provided the controller with adequately sized power and ground wires and none of the wiring got cut / chafed then stuff happens.
Inside of the controller looked ok. It did it again, came on with the car off. I unplugged the sensor wire for the sensor that is on the radiator and the fans shut off. This seems strange as if I remember correctly there is no 12v power on the sensor.
I would vote for bad sensor. How is the sensor configured? I have an Audi/VW sensor. It has 3 wires, 12V in and then low speed out and high speed out once temps are made. Some sensors are a ground, when temp is made it completes the ground circuit to power fans. If using the latter type, that would explain what you are seeing. The sensor failing closed and ground circuit is completed.
Depends how system is wired.
Reactions: Mstng93SSP
But thinking about it now, the fan does run for 1 minute or so after the car is shut off. Maybe the sensor is bad?
The fan running after the car is off would be because coolant is still above trigger temp of the sensor and it takes a minute or so to cool it down. Your fans and control system are powered directly from battery power, not key-on power. Mine does the same thing - I have Contour wiring and control system with a VW sensor - if I shut car off when fans are running, they will continue to run for a minute or two until sensor gets cool coolant and shuts down. My sensor is in lower rad hose.
