  • 1994 - 1995 Specific Tech
Electric Water Pump
  • Thread starter Thread starter NitroJas
  • Start date Start date Aug 31, 2005
N
NitroJas
27
  • Aug 31, 2005
Is anyone running an electric water pump on a 5.0. My 5.0 is pretty much stock is I was looking at CSR water pump for a small block but don't know if it would fit. My water pump just took a dump it is leaking from the impellar bearing i guess since I can see it leaking from behind the pulley. Thanks for any help.
- Jason
94opalgt
358
AKRON,OHIO
Sep 1, 2005
  • Sep 1, 2005
someone just came out with one.cant remember who and i dont know if it is for use daily drivin cars are not,meaning if it has the hookup for the heater or not.all the ones i looked at did not.someone will chime in and let you know for sure though
Redsnk95
2,243
Houston, TX
Sep 1, 2005
  • Sep 1, 2005
If your car is stock you will be fine with a stock FRPP 94/95 replacement pump unless your just wanting an electric water pump. Meziere has a 94/95 specific electric water pump with and without the idler pulley, around $400 dollars. CSR does not make an electric pump for our timing cover. The FRPP replacement pump can be had from jegs or summitt for about $85.
Troy
ProKiller
3,064
15
78
PA
Sep 2, 2005
  • Sep 2, 2005
you don't need an electric pump, don't waste the money. just get a replacement pump or the only other thing i would do would be get an edelbrock. I'm almost positive they just came out with a model for our cars.
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
water pump pulley stock diameter
  • KAWMAN2
  • Jun 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
General karthief
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
C
1997 3.8l v6 timing cover mismatch *eBay guaranteed fit* haha please HELP
  • chasondragons
  • Apr 3, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 3, 2026
chasondragons
C
