Ok, my 94 cobra is still draining the battery if it sits for more then 2 days. I hooked up a multi meter between the negative post and battery cable and see there is a draw. I pulled EVERY fuse and nothing changed. I also tried this same method with a test light and the light never went out. I also tried completely unplugging the alternator, no change. I unhooked the starter cable at the starter, no change. I completely unplugged the stereo and amps, no change. I replaced the airbag module (because it was bad), no change. I unplugged the cluster, no change. I replaced the keyless entry module because I had one, still drained. I unplugged the ccrm and no change. Electrical is not my thing so unfortunately this thing might be going to a shop that does electrical. This will be the first time any of my cars will go to a shop for anything. Kinda depressing. Any other thoughts before I farm this problem out?
