electrical gremlin (long post)
steel1212
1,180
Frankfort, Ky
Ok I've blown 3 constant voltage regulators, the box looking thing on the back of the gauge cluster, in the past 2 days. I have a 65 that I put a 66 gauge cluster into so I could have the gauges instead of dummy lights. Anyway I went to put in a new fuel gauge, thought mine was broke. Wired it up and turned on the key to see if it worked and I blew the gauge fuse :mad: off to autozone for a fuse. Put it in checked wires, everything looked good, turn on key and fried the regulator. Had another one from my 65 cluster put it on and fried it and realized I had wired the fuel gauge wrong, wired it up accoreding to the manuel, checked everything to make sure the rest of the wireing was right and got a new regulator and plugged it up and it worked :D
On my way to the track tonight stopped for gas and filled up, fuel gauge still goes only half way :shrug: ok something still not right but the rest of the gauges worked. Get to the track stop in at the local gas station for a pop and start the car back up, no gauges WTF!! Well I drove it an hour at high way speeds with it not even half way to hot so I ran it anyway with no problems but I completely stumped now. Can anybody help me out or do I have to rig something up so I'll have gauges?
when you changed the cluster did you also change the dash harness and the engine compartment harness ? been told that you have to change both when doing the conversion . but not sure since i have never actually performed the conversion .
