- Jul 8, 2004
- 15
- 0
- 0
Alright, recently my headlights started flicking on and off and then one night the only thing that would work were my headlights...no fogs no rear night time lights no yellows or gauge lights. So I decided to do this and see if it would help(the gt fog light fix) http://www.corral.net/tech/maintenance/foglights.html
Well I did that today and once I had it done with I turned the lights on and same old...just the headlights. Then I found out fuse 4 was blown, it had a 15 amp and i put another in and switched on the headligths and it blew. So i put a 30 amp fuse in and turned on the headlights and they worked...sort of.....the headlights, yellows, and fog lights all worked but still no rear night time lights. So I was a little relieved to see I was making progress...until I saw the wires from the headlight switch smoking. The 2 brown wires started melting along with the light brown wire across them in the switch. Now I'm stuck with half melted wires and I don't know what to do. This is probably due to a short in a wire somewhere right??? Does anybody know what I can do??? Any info is appreciated. (1991 mustang gt)
Thanks
Thanks
