Electrical Guys, Help Me!
gcwh02
515
pottstown, PA
Ok, ever since my mechanic has done my auto-t5z swap i have been having this problem with my battery not charging up from the alternator. The alternator is good, i took it to advanced auto and got it spun on a machine. The battery is good. My mechanic is clueless, he replaced the alternator wires, they all get juice, he replaced almost all the wires going from the starter solenoid. He said he it is getting juice when he tests it, but when I start it and he puts the meter on the battery and i rev it, the alternator is not charging the battery one bit. He said he checked almost every hot wire in the engine bay also. It's still in the shop and I need some serious help. Thanks
Did he leave the voltage sensing wire off? It is integral to the stock charge cable and if that cable was replaced, the sense wire might not have been reattached to battery power.
Good luck.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-90 wiring and lots more…
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
Diagram courtesy of Tmoss and Stang&2birds.
Disconnect the battery and get out your ohmmeter. Check the alternator wiring to make sure you have continuity from the alternator to the battery and the sense, regulator & field leads.
gcwh02 said:
not quite sure what u meant hissin50 haha but he had everything hooked up, we had my car running while also when he checked to see if the alternator was juicing the battery. thanks for your input
In JR's cool diagram, there is a switch and sense wire that Tees off of the orange and black charge cable. If someone replaced most of the wiring on the starter solenoid, this S&S wire might have been left off. The simple question on that is: Is the battery light on?
It is a very long shot, but was worth asking since it takes 30 seconds to check.
Good luck.
Good luck.
No my battery light is not on, I am pretty positive all the wiring is back on. Its just weird b/c when he cleaned the ends of all the connections on the battery, ground, solenoid, etc., we got the alternator to charge up the battery for like 5 sec. and then it stopped and it hasnt been charging yet
