electrical Issue
  • Thread starter Thread starter Cobain03
  • Start date Start date Apr 9, 2006
Cobain03
996
Lexington, Ky
Apr 9, 2006
  • Apr 9, 2006
i got a problem folks. when i use my turn signals, my radio flashes. i have the power wire to the radio running staright to the battery, and i have tried a couple of places to hook up the acc. wire but to no avail. where can i hook the acc wire? what do you think causes the surging?
Az Pete
711
18
49
Panama City, Fl.
Apr 9, 2006
  • Apr 9, 2006
Most likely a ground missing. Had the same problem with my '66 and found a ground on the inst. cluster was loose. Tightened it and no more problems. As for the acc. can you use this (http://hammar.dyndns.org/~djhamma/wiring/wiring1965.htm) wiring schematic to go to the original location?
Cobain03
996
Lexington, Ky
Apr 12, 2006
  • Apr 12, 2006
anymore ideas? i checked the inst. panel and had no luck
Cobain03
996
Lexington, Ky
Apr 12, 2006
  • Apr 12, 2006
here is a reply my dad got on one of his forums...
Try running a jumper wire from the back of the voltage regulator directly to the negative battery post. The voltage regulator is only grounded by its attachment to the inner fender well. Corroded bolts, corroded fender well, paint are likely culprits for preventing a good ground. This solved all similar electrical problems (jittery amp meter, dimming lights and slowing of blower fan when slowing down, funky dash lights with turn signal, etc.) on my '72 Cougar.
whatcha think?
Cobain03
996
Lexington, Ky
Apr 12, 2006
  • Apr 12, 2006
i was going over the wireing diagram and i thought it could be a alternator problem (as far as mix matched locations). well i got to looking and i dont have 4 places to tie in a wire to as shown below.
i have a 5th one to the far left center. whats this?
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
W
Interior and Upholstery New Member auto dimming mirror install issue
  • WigSnatcher92
  • Aug 25, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 28, 2025
Mustang5L5
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
