Electrical Issues - Alternator?
Me again so soon.
My car cuts off when disconnected from the battery. I just installed a new starter and alternator (both tested fine). I would normally point the finger at the alternator for this type of trouble. But it works fine and tested fine. Starter solenoid seems to be fine as well. I plan on replacing the the wires that connect to the alternator tomorrow. But I was wondering if there are some other things I can check in this process. ALso if anyone else had this problem and what you did to solve it.
After doing a search it seems I need to do a little more homework and look into a higher amp alternator. Also I do have a electric fan that is run by a switch in the car, maybe I need to look at that as well. Also never thought to check for "crispy" wires.
If anyone else has somethings I should check out please let me know. I am kinda dumbfounded on this one.
Don't disconnect it from the battery :)
Sorry I can't help ya much, but the 3g alternator upgrade is definately worthwhile, especially since you've got an electric fan. Bump for ya.
Well I just disconnected it from the battery to see if the alternator is doing its job. I theory the car should keep running without being connected. It runs off the battery when connected so something is wrong with that system. But thanks, looks like I will be getting a larger amperage alternator.
On an computer-controlled car, I would not be disco'ing the battery with the car running.
The alternator is protected with a fusible link.
Good luck.
My car is carbeurated.
And I do not see any fuseable links at all under the hood. Maybe thats the issue. Is there a place I can view the wiring diagram or does anyone have a good pic of how their setup is? I just got the car so i am not sure if the previous owner cut wires or whatever.
I am not sure where to start to find out what the problem is. Anyone have any ideas. I went to my local autozone about a high amp alternator and they looked at me like I was crazy. You can only get hi amp alts online or sth?
A sig with your year of stang and mods would really help at this point.
The standard upgrade when using parts store parts is an alt for a 94-95 GT (there are other cars which use the 3G alt, but I would have to look up years and models which have proper clocking).
Stock, there is a handful of fusible links off the starter solenoid hot-post. Who knows what happened to your car - hence why more info about your particular ride is needed.
Good luck.
I am sorry to be such a n00b (I have onlyhad the car for a few days), but could you let me know what more info you/anyone would need, to help me out? I can also take a pic of the engine compartment would that help as well? I'll add some info to my sig as well...... But here is a quick run down...
85 stang 5.0 (not a GT)
T-tops
5 speed manual
4 bl carb
electric fan (switch inside the car)
everything else is completely stock as far as I can tell.
You can't disconnect an alternator - it's not like a generator!
The Alternator unlike a generator needs to be connected to power to produce power.
Disconnect the battery and it will die this is perfectly normal!
The proper way to test your alternator is to hook up a volt meter and check the charge voltage - it should be around 14-15 volts. Turn on all your accessories and watch to see if voltage does not drop under 13volts.
I presume the voltage will drop if you have an electric fan(they draw 22 amps). So I say like the other chap - put in a 3G and put your problems behind you.
The stocker charges very little at idle while the 3G will probably do 50-60 amps or so(almost as much as a stoker at full pin)
In addition, if you install a 3G - upgrade your harness that goes from the starter relay to the alternator - you'll roast the stock 10 guage if you don't. Use stereo shop wire and fuses(100 - 150amp) and you'll be fine.
I think Ifound the problem but I think it needs a professional.
I think before I change the alternator I need to address this mess....and oh what a mess.
I think I better seek pro help...:( :damnit:
Hi Webshot! Are you comfortable with schematics? Using Chiltons etc or similar you can easily diagnose these wire troubles yourself. The "charge" wire from the stock alternator is two wires(black with orange stripe - I believe) which leaves the alternator and about 1 foot or so out join to become 1 single wire 10 guage which go directly to your relay. Just take the top plastic wind guard of the top of your radiator off and this will permit you to follow it end to end.
You can replace it/repair it yourself. Ford had some recalls and fire issues with the first part of this harness - so while your at it check the copper wire for signs of heat, britlleness and inspect the wire's insulation to see if it too is not dry rotted, brittle or burnt. Other than that it about a 1hour deal to check evrything throughly.
