Electrical nightmare!!!
  • Thread starter Thread starter Deraild
  • Start date Start date Dec 3, 2008
D
Deraild
  • Dec 3, 2008
I have a 68 coupe with a 302. I could not get the blinkers or the brake lights to work so I put in a new firewall to headlamp harness and a new taillight harness. When I turn on the left blinker the right taillight flashes as the left parking light flashes. I know it sound like I plugged in something backwards but I made sure when I installed the new harnesses I plugged everything in to it's color coded spot. I'm pretty sure the parking lamps arent even made to work as a blinker, that's the side markers job right? Can anyone help me!!!
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Dec 3, 2008
  • Dec 3, 2008
Sounds like the under dash wiring has issues. Check the steering column wiring and see if you find that it has been hacked up.
rbohm
6,698
550
204
tucson,az
Dec 3, 2008
  • Dec 3, 2008
check all your grounds as well as making sure that you hooked things up right.
BarnStang
1,260
Hagerstown, MD
Dec 4, 2008
  • Dec 4, 2008
Replacing harnesses on these cars is not always the answer. THe wiring can be high maintenance, but it's also a pretty simple system. You need to get a decent test light and start working one problem at a time. I would start with the brake lights since that's the easiest to troubleshoot. And if the fault in the brake lights leads to the turn signal switch, it may clear up the other problems when replaced (if thats the problem).
On the brake pedel there is a contact switch with two wires to it. THere should be 12v on one of the wires all the time. CHeck that first. When you push the brake pedel, the switch should close and send 12v out the other wire. Make sure it does that. That 12v goes up to the turn signal switch, through the switch and back down TWO wires-one to the left turn signal/brake lamp, and the other to the right turn signal/brake lamp.
With the brake pedel pushed you should have 12v at the socket in the trunk on the Green w orang strip wire (left) and the Orange w/blue strip wire (right)
Check that and post back. Worry about the turn signals later. And we do want to know if the connection at the steering column harness has been butchered up. Tere should not be any cut or spliced wires at that connector.
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
J
Electrical Cluster bulb LED swap gauges bounce
  • jpfox
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
gkomo
M
Aftermarket Brake light help needed
  • Mustang Steve
  • Mar 17, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 17, 2026
Mustang Steve
M
