Guys I need some help. The car is an 89 mustang. The problem is that the momentary hi-beams work but when you push the switch back to lock them on they dont work. I could care less about them because I never use them but they need to work for insepction.
Here what ive found, the switch checks out fine so that is not the problem. The connector to the switch seems to be ok but the half of it that houses the contacts for the "locked on" function of the hi-beams is slightly melted, im guessing this is a sign of a previous problem. (I can get pics of this too if you want).
The next thing I did is trace the two wires connected to the connector (red w/ black stripe) and (red w/ yellow stripe). I traced the red w/ black stripe first and it goes into the main harness and out to the headlights. The second wire is where I think the problem lies. I traced it as best I could and as far as I can tell it goes into this brown connector under the dash (pics below). The thing is the brown connector is NOT plugged in anything, and there nothing up there that I can see that its supposed to plug into.
[/IMG]
[/IMG]
Can anybody tell me what this goes into, maybe look under your dash? Anyway sorry about the long post and thanks in advance for the help.
P.s pay no mind to the dirty carpet
